K-Roll931
Joined: 08 Jul 2017 Posts: 76 Location: Southfield, MI
Posted: Mon Mar 25, 2019 2:35 pm Post subject: Blinkers work but Hazards Don't? |
This is a confusing situation that's been going on for a while. At some point that I cannot pinpoint, my hazard switch stopped working as it should. When I flip it, the indicator on the gauge stays solid. However, my blinkers are perfectly functional on all four corners after replacing the fuse, relay, and switch/stalk.
All that's left at this point is to replace the hazard switch itself. I would like to confirm that's the logical assumption before I throw money at it. _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
Posted: Mon Mar 25, 2019 6:29 pm Post subject: |
Replace the switch _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
K-Roll931
Posted: Tue Mar 26, 2019 4:05 am Post subject: |
New switch has been ordered. Will report back when it arrives and is fitted. _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
Posted: Tue Mar 26, 2019 4:12 am Post subject: |
You could also try taking it apart and cleaning it, sand the contacts.. _________________ 80 Turbo - Slightly Modified |
K-Roll931
Posted: Wed Mar 27, 2019 7:08 am Post subject: |
| Fasteddie313 wrote: | | You could also try taking it apart and cleaning it, sand the contacts.. |
True. I'm getting into the habit of keeping any parts I replace so this could maybe be reused down the road. _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
K-Roll931
Posted: Tue Apr 09, 2019 9:28 am Post subject: |
Replaced the switch and no change. Hazards still don't work. Time to check the fuse again. _________________ '80 931 M471 - Dolomite Gray -> Monaco Blue |
