Patrick
Joined: 05 Dec 2007 Posts: 278 Location: Manila, PHILIPPINES
Posted: Tue Oct 10, 2017 3:34 pm Post subject: Weber dcoe question re: pump jet cover screw Rubber O-ring |
Hello ! I just got through giving my jets and any screw on covers a good soaking in strong solvent for about a day and a half. I mistakenly left the accelerator pump jet "Pump Cover Seal (rubber o- ring)" attached to the pump cover screw..so its history... Its virtually impossible to get weber parts over here. Is it ok to substitute just any gasoline resistant O-ring that will fit snug or tight ? Is it critical to get one with exact measurements like the oem one ? So does the rubber O-ring function to just keep it from leaking, or does it additionaly have to deal with pressure ? Thank You ! _________________ 1979 924 U.S. version
Single sidedraft Weber 40 |
Qik Nip
Posted: Wed Oct 11, 2017 4:21 am Post subject: |
Patrick:
Assuming that you're able to find an gasoline resistant O ring that is both the identical inside and outside diameter, I'm pretty sure you'll be okay. If you end up needing the original, I'd contact Carbs Unlimited. I'd guess they'd happily mail one to you. Here's a link to their page.
Rick
https://www.carburetion.com _________________ '79 NA 924 Land Speed Car
Great Lakes SCCA SM points champion '09,'10,'11 |
Posted: Wed Oct 11, 2017 4:45 am Post subject: |
I am also a Redline Webber reseller. If there is a rebuild kit available, I can get it. Post a part number and diagram and I can look into it for you.
If that doesn't pan out, McMaster-Carr have an excellent website with a wide range of o-rings. They would be my next choice if OEM repair kit isn't available. _________________ erstwhile owner of just about every 924 variant ever made |
Patrick
Posted: Thu Oct 12, 2017 9:14 am Post subject: |
Thanks for the replies guys ! I just went for locally available gas resistant o-rings. And you would be my first choice for weber parts ideola. _________________ 1979 924 U.S. version
