chris79
Posted: Sat Aug 26, 2017 2:10 am Post subject: Spacers with stock 924 na wheels |
Hello,
anyone know if there are some specifics rings for install spacers on standard 924 wheels, that have conic hub inside? _________________ Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro |
Sunset924
Posted: Sat Aug 26, 2017 12:25 pm Post subject: |
| The center bore of thr 924 (as well as most vw and audi vehicles) is 57.1mm. If you select a wheel spacer that is a 57.1 hub-centric, the spacer will fit properly in the cone or center of the wheel and on to the hub of the vehicle as well. |
chris79
Posted: Sat Aug 26, 2017 4:00 pm Post subject: |
No, I buy 4x108 57.1 spacers, but there is about 2mm from spacer and wheel, my mechanic advise me to install rings.
Some times ago after a trackday I found rear wheels bolts unscrewed and this can be' the cause.
Then I modified some rings for fix rear spacers, but is hard work without specifics tools.
I would like find the exact rings for my wheels because I have to install spacers even in front axle. _________________ Porsche 924 2.0 na 125hp (1979) euro
Posted: Sat Aug 26, 2017 8:34 pm Post subject: |
Take a caliper and measure the diameter of the hub, most people believe the 924 has the same stuff like Audis or VWs but it does not.
Measure the hub diameter, measure the spacer diameter and ask a local machine shop to make a set of centering rings for you...they should not cost more than a beer or two. _________________ Supercharger and EFI kits
https://www.the924.com |
Sunset924
