AFM vacuum port(?) has come off!
Chaos
PostPosted: Thu Dec 01, 2016 7:40 am    Post subject: AFM vacuum port(?) has come off! Reply with quote
Hey gents, could use some advice here.
The connector on the bottom side of my AFM housing (see 2nd photo here, for reference) has recently pulled straight out.
I tried re-adhering it once already with some JB Weld stick since I had it laying around, but that definitely hasn't done the trick as it's pulled back out and just seems to seal terribly now.
My next attempt was going to be to clean it off, coat it in red RTV silicone, and gently tap it into place with a mallet. But, I figured that before I do something else potentially stupid , I should see what suggestions everyone might have for how I should re-attach and seal it back up (preferably in situ).
'81 US 931 "Rochelle"
Ozzie
PostPosted: Thu Dec 01, 2016 8:05 am    Post subject: Reply with quote
Had similar on a carby- used a special loctite which is thicker and no problems
Its AUTO and its BLACK
Montego Black on black/red
