friggin
Posted: Mon Nov 16, 2015 2:00 pm Post subject: Raceseats |
Does anyone have raceseats? I'm looking to put the corbeau fx-1 in my 79 924.
Just wondering how you like them, how well they fit, how you mounted them, and some pics of them.
Also planning on a momo mod 30 steering wheel to go along with them. _________________ 1979 924 stocker soon to be autocross beast |
Posted: Mon Nov 16, 2015 3:32 pm Post subject: |
Yep.
Bolted to the floor with double locking sliders and side mount brackets.
I had adapter brackets, but they weren't needed for my seats.
Unless you have a proper roll bar or roll cage, use the stock seat belt instead of a harness.
The only issue I have with smaller steering wheels is the steering effort goes up considerably, especially when autocrossing or driving at slow speeds.
 _________________ Stefan
Posted: Mon Nov 16, 2015 6:18 pm Post subject: |
I have cobra imola seats, made 3mm steel brackets so they fit the original sliders.
Regarding the wheel the most important thing is to have a wheel with some depth, it makes heaps of room for your legs. After you tried that driving a std 924 will feel very uncomfortable..
Click the link in my signature and there are some pics.. _________________ 1980 924 Turbo
Posted: Tue Nov 17, 2015 12:44 am Post subject: |
I have these Sparcos in the Club Sport:
I don't know the model, as there were no markings on them anywhere. I got them in NOS condition from a private seller.
Mounting them was a bit of an adventure. These seats require side mount brackets, which I mounted to the Sparco double locking sliders and a base plate that bolts to the stock seat mounting locations.
I love these seats. With the harness on, you are absolutely locked in...can barely unlock the door or roll down the windows. _________________ erstwhile owner of just about every 924 variant ever made |
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Tue Nov 17, 2015 2:36 am Post subject: |
You should definetly use side brakets...I made a custom bottom bracket to fit mine and it raised the seats to high. (my legs where hitting the steering)
This is why I went with a flat bottom steering wheel
Also calculate closely as I can't use a helmet in mine...defeats the purpose of racing seat if you ask me! _________________ 1979 924 NA |
friggin
Posted: Tue Nov 17, 2015 3:48 pm Post subject: |
That's the reason I'm getting the new wheel is because it's flat bottomed. I'm 6'0" and my legs hit the wheel with everything stock right now. And I know the race seats have higher sides so I figured the only way I'd be able to get in would be with a flat bottomed wheel.
I'll make sure I can fit a helmet, if I can't the car would be pointless as it's going to be 80% racecar 20% daily driver.
Has anyone ever used the bottom mounts from corbeau? My buddy said without the side mounts these seats are a little flimsy. _________________ 1979 924 stocker soon to be autocross beast |
Posted: Tue Nov 17, 2015 4:09 pm Post subject: |
I have a removable wheel in mine for that exact reason.
If the seat isn't FIA rated, it should be braced to the roll bar/roll cage (even then it's not a bad idea). It's on the list for my prep for next year, to add a roll bar to mine with a proper seat brace and harnesses.
Side mounts allow the seat to be lower and mounted better and allow adjustment of the back angle more easily and accurately. _________________ Stefan
