Lau Christophersen
Joined: 17 May 2013 Posts: 123 Location: Denmark/Copenhagen
Posted: Sat Nov 21, 2015 7:31 am Post subject: New 931 engine - need some advice |
I need some help/advice for my new 931 engine.
The plan as it is now:
Rebuild the 931 engine, but with 924 N/A pistons and mill the block down but how much?
I used Ideolas compression ratio calculator, and if i did it right i get the following:
Mill the block by 1mm: cr = 8.8:1
Mill the block by 1.5mm: cr = 9.1:1
Mill the block by 2mm: cr = 9.6:1
Another thing is the head gasket, that will change the cr-ratio too, but is the original head gasket strong enough?
The plan for the turbo:
I want to make the exhaust pipe/manifold like the 951 and in 3" stainless from turbo and back, so the turbo will end up on the drivers side of the engine. But which turbo should i choose, any recommendations?
The plan is to drive with EFI, i will buy a VEMS setup from Raceboy and use some 440cc injectors.
Another thought was to remake the intake manifold so the throttle body will be mounted forward - pointing toward the FMIC. Should i look for another throttle body when i want to redesign the intake manifold or just stick to the original one?
Many questions, i hope you have some thoughts you want to share with me, the biggest problem in my head right now is the boost VS. CR-ratio.
Low boost and high CR or high boost low CR? or something in the middle?
Maybe i have to point out that it is just a funny sunday driver, it is not build for the track at this moment.  |
Posted: Sat Nov 21, 2015 7:48 am Post subject: |
I wouldn't mount the turbo under the intake, your intake temps will suffer for it, the 951 does as well.
Be aware that you can run into flow issues to the front cylinders if you run a front mounted throttle body and a poorly designed plenum.
The stock intake is actually pretty well designed other than the plenum being slightly small and the throttle body is in a pretty inconvenient location for your use.
I would be careful of how the air flows into the plenum. I've heard good things about dual-plenum solutions along with angled plenums that place the throttle body entrance far enough away from the runner inlets to help balance the flow rates.
You should also look at ensuring your cooling system is up to the demands as well. Perhaps look at an electric water pump and reverse cooling the motor to balance the cooling across the cylinders (3 & 4 tend to get the hottest)
Good luck! _________________ Stefan
Lau Christophersen
daniel
Posted: Sat Nov 21, 2015 3:39 pm Post subject: |
Best way to increase compression is to use a cometic head gasket.
To answer your question, the standard head gasket has stainless steel fire rings - you won't break it easily _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Sat Nov 21, 2015 7:18 pm Post subject: |
Two options for me. Follow the path Raceboy has already proven in his engines in his cars or buy the parts and the specs as proven by Mittelmotor. Both have reliable results over 350bhp. Other routes could like Dutchpug or indeed Joakims. If I built another engine, I would follow a proven model. I prefer high boost for fun. High compression, low boost is more drive able for a daily but less fun. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Sat Nov 21, 2015 7:21 pm Post subject: |
| daniel wrote: | Best way to increase compression is to use a cometic head gasket.
To answer your question, the standard head gasket has stainless steel fire rings - you won't break it easily |
Bust two stock head gaskets in two years. Now gone to MLS and survived 9+ months so far. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
