Jamie_924
Posted: Mon Jan 19, 2015 4:41 am Post subject: baffled/gatef sumps! |
Hi,
Just looking for a bit of info into the oil feed on 924s on track.
Has anyone had problems with surge or starvation on track and baffled their sumps?[/list] |
Posted: Mon Jan 19, 2015 5:34 am Post subject: |
I use a Ishikara Johnson crank scraper on my 2.5 that slows the flow of oil up the right side of the sump, and I have never had oil pressure problems. However, Lindsey Racing here in the US sells a kit that creates a trap door and improved pickup that is fairly inexpensive and is used by many people. _________________ Toofah King Bad
Jamie_924
Posted: Mon Jan 19, 2015 5:51 am Post subject: |
Thanks for the reply....appreciated, maybe I should have been clearer, mines a n/a 2.0
Before the mod did you find any problems or have you fitted the setup as a precaution?? |
Posted: Mon Jan 19, 2015 6:04 am Post subject: |
Scraper was very inexpensive, and I liked the increased engine efficiency and oiling efficiency it provides.
Sorry about the misunderstanding. . .I saw "924s" and assumed it was a 2.5. _________________ Toofah King Bad
Posted: Mon Jan 19, 2015 9:12 am Post subject: |
I use the IJ crank scraper and an AccuSump on my 2.0. On board data acquisition shows no pressure drops ever on track. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Mon Jan 19, 2015 1:26 pm Post subject: |
I use a IJ scraper for the benefit of cutting down oil mist in the engine (which robs hp). I had no oil pressure issues before or after installing the scraper.
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Mon Jan 19, 2015 4:13 pm Post subject: |
Will you be running slicks? Otherwise I wouldnt bother, I have been track driving the last 10 years with my na and turbo without any problems, though on R compound tyres like Michelin pilot sport cup, R888 etc... _________________ 1980 924 Turbo
Jamie_924
Posted: Mon Jan 19, 2015 11:33 pm Post subject: |
No worries rasta I did think twice when writing that!
Thanks for the comments guys, I will be using r888 tyres on track. |
