7 yrs later
PostPosted: Wed Oct 15, 2014 11:08 pm    Post subject: 7 yrs later Reply with quote
Joes924racer
https://plus.google.com/photos/108130127296091343442/albums/6070392081540627985]
PostPosted: Fri Jan 16, 2015 2:03 am    Post subject: Reply with quote
10 years ago. https://plus.google.com/117282416084851417006
PostPosted: Fri Jan 16, 2015 2:06 am    Post subject: Reply with quote
Is it running?
PostPosted: Tue Jan 20, 2015 12:21 am    Post subject: Reply with quote
Hell yeah, needs front end aligned (plus this requires tearing down the control arms as I believe I didn't install the bushing all the way. They need to be pressed on don't they.) It needs a tune I still need to get a afm wide band set up to fill the hole I made for it in dash. But yeah it starts, charges, cools itself, revs, shuts down and restarts, lights work (blinkers need wired to new tree you know the blinker wiper on /off thingy under steering wheel.) and gt headlights need finished. Though yes sir it runs good wur works like it should injectors spray cone. Another pita though, oil pressure Guage was leaking at back of cylinder. head so I applied sealant and now the tube is plugged must of used to much. But again yeah it runs strong has a new clutch and motor rebuild. Hey I see the road.
