Fuel Leak At Base Of Tank - What Gasket
TYPE111
PostPosted: Wed Jan 28, 2015 10:15 pm    Post subject: Fuel Leak At Base Of Tank - What Gasket Reply with quote
The big nut which goes into the bottom of the tank is dripping, tried to tighten it up but still drips. Looked as though the PO has but gasket sealant around it in the past. Tried to do if again but too wet with fuel.
Is it a rubber or cork gasket or should the gasket sealer be used again?
Cheers
David
Trust, Then Verify
PostPosted: Thu Jan 29, 2015 12:33 am    Post subject: Reply with quote
New ones are rubber, Pelican has them for $8.25 part number, 928-201-187-02-M100
Creech
PostPosted: Thu Jan 29, 2015 11:57 am    Post subject: Reply with quote
Ordered mine from Pelican. Little tip, find another way to drain the fuel tank before just cracking it open from there. I drove with the gas light on for a day and figured it would be low enough. Nope. Spilled a couple gallons of gas in the driveway.
1981 Porsche 924 NA
TYPE111
PostPosted: Thu Jan 29, 2015 10:20 pm    Post subject: Reply with quote
Had a comment that the nut doesn't look standard. Can't see how to post a pic. Can anyone take a pic of the connection at the bottom of their tank to see if it's the same as mine.
Cheers
Trust, Then Verify
PostPosted: Fri Jan 30, 2015 12:06 am    Post subject: Reply with quote
Pelican or Autohausaz, has the entire 'nipple', fuel filter, o-ring as a complete unit.
Ok, found my spare, it's from Autohausaz.com, comes with an o-ring, don't order one separately. Taking the pic with my 951~!
