Can't get injectors to open using afr screw
McMichem
PostPosted: Tue Aug 04, 2015 3:31 am    Post subject: Can't get injectors to open using afr screw Reply with quote
I recently purchased a 931 and after having taken care of some other things I am trying to get it running.
The car will start after cranking for about 5 seconds, run rough and then stall. it doesn't matter how much throttle you give it, it has little or no response.
I am assuming I have some vacuum leaks but I think it is more of a fuel pressure issue that I want to check out first.
The only way the previous owner could get the car to run and continue to run was to hold the metering plate down a tiny bit, therefore opening the injectors and giving it the fuel it needs. Adjusting the afr screws to tune it so it opens the injectors then back off a little twist does nothing, they just won't open. Fasteddie suggested checking the "Pop up valve" so I plan on doing that when I get home.
Also I have been reading there is a cover for the screw, is the screw that big of a vacuum leak and would it throw off the engine that much?
1980 931 ~ 67,000 miles
PostPosted: Tue Aug 04, 2015 4:00 am    Post subject: Re: Can't get injectors to open using afr screw Reply with quote
Actually its the system pressure regulator plunger as I understand it, or the main fuel pressure regulator, it is labeled "Push-up valve" in the pic..
I find this pic very handy.. Thank you whoever made it..
PostPosted: Tue Aug 04, 2015 4:25 am    Post subject: Reply with quote
What you are describing sounds more like a fuel delivery issue to me, probably malfunctioning WUR, bad injectors, malfunctioning fuel distributor, or some combination thereof. The best (and IMO, only) way to troubleshoot is to start with a proper test of the CIS system. Tutorial here.
McMichem
PostPosted: Tue Aug 04, 2015 9:54 am    Post subject: Reply with quote
I don't think the correct amount of pressure was ever getting to the fuel dist.
I removed the fuel filter ( someone stripped the hell out of it) so I ended up having to break the fuel line to check it. But there is so much resistance I can hardly blow through it. Gonna replace that and the fuel line now >.> and hopefully it's that and nothing more.
PostPosted: Tue Aug 04, 2015 10:07 am    Post subject: Reply with quote
Make sure to install the replacement filter in the correct orientation, arrow pointing toward the windshield. Common mistake to put it on backward...
