Shurick
Posted: Tue Nov 11, 2014 4:03 am Post subject: Q: Coilover + t-bar in the rear - how to select springs? |
Just considered not to mess with torsion bars, just to put some coilovers. And the question is how to select appropriate springs? I have 24,5 t-bars and don't want to go crazy with stiffness and lowering. What springs (stiffness and length) should I use to match, say, #260-280 coils in front struts? _________________ WBR, Shurick
'86 924S -- R.I.P.
jason c
Posted: Tue Nov 11, 2014 1:58 pm Post subject: |
| The 24.5mm bars are about 213lb so if you like the handling as is, go with the same ratio f&r. Some prefer the front stiffer, some prefer the rear stiffer so it depends on your preference. Size & length will depend on the type of coilover. |
Posted: Tue Nov 11, 2014 2:34 pm Post subject: |
I prefer to do the torsion bars to avoid altering the center of gravity, but if you look around online, the stock T-bar spring rates are available and you can simply add the desired coil spring rates on top of that.
Check out the stickied Cheap Shock option thread in this area for more info on shocks, springs and struts, etc. _________________ Stefan
jason c
Posted: Tue Nov 11, 2014 2:49 pm Post subject: |
I have t-bars and coilovers on my racecar, but the combined rate is 1100#.
The problem with having both in this situation is he wants 260-280 in front. If the t-bars are over 200#, keeping the rear close in weight will require very soft coils. |
Shurick
Posted: Tue Nov 11, 2014 4:01 pm Post subject: |
Thanks for your replies.
From the clarks garage 24,5 mm t-bars are 149 lbs/in and I was thinking that it's a right figure (http://www.clarks-garage.com/shop-manual/susp-15.htm).
The problem is that my rear suspension feels a bit overdamped with yellow koni sport shocks and those t-bars. It's nervous over the bumps.
Also I'm not shure that putting 100 lb spring over the to the rear will result 249 lb in total. I have 924S arms and 23.3 offset fuchs in the rear. It makes about 200 mm of lever between the wheel center and the shock attachment point. _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Wed Nov 12, 2014 2:40 am Post subject: |
| Shurick wrote: | | The problem is that my rear suspension feels a bit overdamped with yellow koni sport shocks and those t-bars. It's nervous over the bumps. |
Did you try adjusting them back a bit? It the car skitters over bumps you may have your rebound too stiff. _________________ Toofah King Bad
Posted: Wed Nov 12, 2014 2:59 am Post subject: |
You might also look around for a shop with a shock dyno to get an idea of what the different settings actually mean.
Many Koni's (and other shocks) can also be re-valved to suit the corner weights and spring rates found on your car.
You just need to provide the relavent data to the shop to start working on a ball park valving. _________________ Stefan
Shurick
Posted: Wed Nov 12, 2014 4:07 pm Post subject: |
They are at the middle position now and I really can adjust them softer. But I definitely need to add some stiffness to suspension, just not 400 lbs. This car spends much time of the time on public roads. But sees some track too.
Found this: http://www.paragon-products.com/kb_results.asp?ID=58
If you know the rate you are trying to achieve by adding coil-overs (such as the Koni 3012) to an existing T-bar , you can calculate the necessary spring needed.
"<desired effective rate> less <effective T-bar rate> divided by 56% equals linear coil-over spring rate"
They also list 24,5 mm t-bar as 149 lbs. But according to their equation I need to add #200 spring to archive desired 260 effective rate. That scares me.  _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Wed Nov 12, 2014 4:10 pm Post subject: |
Replacing t-bars while refreshing the bushings in the rear end makes so much more sense. _________________ Toofah King Bad
Shurick
Posted: Wed Nov 12, 2014 4:25 pm Post subject: |
| Rasta Monsta wrote: | | Replacing t-bars while refreshing the bushings in the rear end makes so much more sense. |
I know. But there's a price factor. I've already refreshed my rear bushings and came with the largest t-bars I had on hand. I had a 924S M030 rear suspension for parts and used alu arms from it too. If I will order larger t-bars, the overseas shipping will double (or triple?) the price. A variety of racing springs can be sourced locally. I can go try and error route easily. Just need a baseline to start from. _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Wed Nov 12, 2014 4:41 pm Post subject: |
Maybe start by looking at the 968 CS, it had some sort of coilovers on the rears. Some helper springs.
Maybe you can find the specs of those springs.
What rear coilovers are you using? _________________ Supercharger and EFI kits
https://www.the924.com |
Shurick
Posted: Wed Nov 12, 2014 8:48 pm Post subject: |
| morghen wrote: | Maybe start by looking at the 968 CS, it had some sort of coilovers on the rears. Some helper springs.
Maybe you can find the specs of those springs. |
I've done some research and results are not ambiguous. Different sources are quoting from 60 to 150 lbs.
| morghen wrote: | | What rear coilovers are you using? |
Currently I have yellow koni sport shocks. A reputable suspension workshop swears they can put adjustable spring perches and springs on them. _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Wed Nov 12, 2014 9:13 pm Post subject: |
I heard that you could put some sort of segments on a cutout groove on the body of the shocks and they will hold.
Its an interesting aproach...but i wonder how much abuse they can take.
| Shurick wrote: | | Currently I have yellow koni sport shocks. A reputable suspension workshop swears they can put adjustable spring perches and springs on them. |
Posted: Thu Nov 13, 2014 1:28 am Post subject: |
| Shurick wrote: | | Rasta Monsta wrote: | | Replacing t-bars while refreshing the bushings in the rear end makes so much more sense. |
I know. But there's a price factor. I've already refreshed my rear bushings and came with the largest t-bars I had on hand. I had a 924S M030 rear suspension for parts and used alu arms from it too. If I will order larger t-bars, the overseas shipping will double (or triple?) the price. A variety of racing springs can be sourced locally. I can go try and error route easily. Just need a baseline to start from. |
There aren't any local sources in Europe for VW Super Beetle off-road torsion bars? Not even places like Norway, etc? _________________ Stefan
Shurick
Posted: Sat Nov 15, 2014 3:12 am Post subject: |
| fiat22turbo wrote: | | There aren't any local sources in Europe for VW Super Beetle off-road torsion bars? Not even places like Norway, etc? |
I will check this. _________________ WBR, Shurick
'86 924S -- R.I.P.
