Posted: Wed Nov 05, 2014 8:17 am Post subject: trying to wrap my head around installing an AFR gauge.. |
the biggest confusion for me is how to keep the stock lambda system happy.. like..
can a wideband sensor produce both wide and narrow at the same time without a "simulator"? like directly? bosche 5 wire??
a simulated narrow band signal from a wideband unit can lag and reduce the performance of the stock lambda?
do you have to just install a second bung for your wideband and run 2 o2 sensors?
so its wideband sensor, sensor controller, and gauge..
controller in the gauge? in sensor? in between?
all afr gauges compatible with sensor/controller combinations?
i just want to end up with a simple non rice gauge, lambda working as intended, and hopefully not having to install another bung in the exhaust..
what am i missing here?
along with a boost/vac next to afr ill be able to really see, and understand whats going on real time in my engine so i can better instantly recognize any problem that may arise and be confident that things are working correctly so im not afraid its going to blow up on me because i feel im blind..
it seems to run perfect.. that's what scares me.. too good to be true.. _________________ 80 Turbo - Slightly Modified |
SlayerSST
Min
Posted: Thu Nov 06, 2014 10:44 am Post subject: |
My innovate lc-1 had two programmable outputs, just set one up as a narrowband and off you go (in fact, one was setup as narrowband default)
Posted: Sat Nov 08, 2014 5:12 am Post subject: |
what do you think of the performance your getting out of the narrow band signal simulator if your useing that for your lambda system?
any experience watching its reactions with a dwell meter on the frequency valve straight sensor vs simulator?
i thought i read somewhere about wideband's narrow band simulation outputs giving unfavorable results due to lag...
ill dive into that innovative n see what i can learn about it... _________________ 80 Turbo - Slightly Modified |
