musicalannette
Posted: Wed Oct 22, 2014 8:50 am Post subject: hi - weak batteries? |
its coming up to winter, i may not use the toofahhh for a while. the battery gets weak and sometimes seems to be beyond repair. i have been told its due to the gradual leakage of charge without starting(charging) to clear the charge receiving plate. makes sense.
but clip a battery desulfator on for 10 mins every 2 or 3 days and this sorts the problem.....any1 had any experience? _________________ I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737..... |
Posted: Wed Oct 22, 2014 9:10 am Post subject: |
Black and Decker sells a nice trickle charger for $20 that will solve this issue. _________________ Toofah King Bad
Posted: Wed Oct 22, 2014 2:31 pm Post subject: |
That and disconnect the battery leads and keep the battery inside away from temperature extremes. _________________ Stefan
