Long time no start
924turborox
PostPosted: Sat Sep 20, 2014 1:37 pm    Post subject: Long time no start Reply with quote
Good evening,
I sadly haven't started my car in 2 years or so and it isn't really at all now :/
I left Stabil in the fuel tank when parked, but still no go.
Any ideas/recommendations?
Thank you,
Rich
1980 porsche 924 turbo 5speed getrag gearbox
PostPosted: Sat Sep 20, 2014 2:10 pm    Post subject: Reply with quote
If it was running fine before and I was feeling super lazy I might try starting fluid.
PostPosted: Sat Sep 20, 2014 6:28 pm    Post subject: Reply with quote
Yepp, try spraying dashboard silicone into the intake while cranking. Maybe take the air filter off first.
Also..if it sat for 2 years you might want to replace the timing belt, especially if its a turbo.
gohim
PostPosted: Tue Sep 23, 2014 6:49 pm    Post subject: Reply with quote
Get someone to crank the ignition key while you stand by the right rear wheel and listen for the fuelpump. Without use, the fuelpump will gum up when with fuel stabilizer in the system.
