kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
Posted: Thu Jul 24, 2014 6:09 am Post subject: Turbo bypass valve, correct parts order? |
Does this order seem correct? I'm not sure what the 'washer' on the sleeve is really for. I replaced the seals and neglected to keep track of the order they came out.
 _________________ 1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. |
Posted: Thu Jul 24, 2014 6:54 am Post subject: |
yep that's right and the piston goes on the other end with spring into it...
looks like the little ring washer is a spacer, or to give the spring correct oem tension.. _________________ 80 Turbo - Slightly Modified |
Posted: Thu Jul 24, 2014 6:56 am Post subject: |
I just made new seals for mine out of leather..
so I was just in there too and have another housing sitting all apart, havent washed it good enough yet.. _________________ 80 Turbo - Slightly Modified |
