Intermittent Starting Problems - Any help would be appreciat
NJ924
PostPosted: Tue Aug 06, 2013 8:57 pm    Post subject: Intermittent Starting Problems - Any help would be appreciat Reply with quote
Hi all,
I have had my 1988 924s for the past 11 years. A few months ago, it would die on me while driving. We replaced the 2 timing/ position sensors and it seemed to be running fine.
Lately I have had trouble starting it. Here is what I am seeing:
- Sometimes it won’t start. This can be after it had been sitting or after I just finished driving it.
- Sometimes it will start, but stutters on acceleration from any speed and I can smell gas in the exhaust (acts like a stuck choke would on a carbureted vehicle). It maintains speed at any RPM with no problem
- Sometimes it runs fine with no problems.. easy start, smooth acceleration
Work that has been done:
- Realigned the Bosch Motronic Air Flow Meter as shown here http://www.youtube.com/watch?v=-11J8XawQtc
- Replaced the 2 timing/ position sensors
- Replaced the DME relay
- Replaced the fuel pump relay
Does anyone have a suggestion where I should look next? As it is, I can’t take the car anywhere for fear of getting stranded.
larchie
PostPosted: Tue Aug 06, 2013 11:21 pm    Post subject: Reply with quote
You might try looking for a leaky fuel injector, faulty fuel pressure regulator, or obstructed ERG valve.
NJ924
PostPosted: Thu Aug 08, 2013 9:26 am    Post subject: Reply with quote
Thank you very much for the advice. I will check those out... Anyone else?
NJ924
PostPosted: Sun Oct 13, 2013 6:34 am    Post subject: Starting Problem update-noticed tach not moving when wont st Reply with quote
Hi all,
I replaced the injectors. One had a crack. The car runs great,... when it runs.
I noticed that, when it won’t start, the tach does not move. I saw a post indicating that a bad sensor showed that symptom (it should bounce when starting if all is well). The other symptom is, on rare occasion, the engine will die and the tack goes to zero (even though it is still turning). So far, it starts running again without me pulling over.
I have replaced both sensors and the DME. Could one of those be bad? Bad wiring? Is there elsewhere I can look?
Thanks,
Frank
p.s. I'm desperate. My wife wants me to get rid of the car
Ozzie
PostPosted: Sun Oct 13, 2013 6:36 am    Post subject: Reply with quote
On the NA the tach gets its pulse from the coil. Don't know about the S but probably the same.
Its AUTO and its BLACK
Montego Black on black/red
larchie
PostPosted: Sun Oct 13, 2013 10:40 am    Post subject: Reply with quote
Sometimes it won't start...
Sometimes it will start, but stutters on acceleration from any speed and I can smell gas in the exhaust ...
... when it won’t start, the tach does not move ...
... the engine will die and the tack goes to zero ...
Intermittent loss of voltage with loss of spark, seems to be the common factor in your list,
So you might start with troubleshooting loose or poor connections and also the parts themselves from starter to ignition coil, ignition coil to distributor, spark plug wires, tachometer, and DME, etc. and (unlikely if the motor turns over when it won't start) the ignition switch itself perhaps worn from extra play from something like weighted keys.
Are there any common factors when the engine dies -- e.g., bumpy roads, turning left or right, rain or high humidity, acceleration, etc.?
NJ924
PostPosted: Sun Oct 13, 2013 11:38 pm    Post subject: Reply with quote
Thanks Guys.
The last time it died while driving was on a smooth road.Most often, I will be driving it one day and then it wont start the next time I try (as you said, it does crank).
When I got the car, 11 years ago, it wasn't running. It had been sitting for a few years with a bad interior leak, The mechanic had to reoplace the fuse blokdue to corrosion.
The connection problem sound like a possible issue. I guess the DME plug should be the first place to check?
Frank
larchie
PostPosted: Mon Oct 14, 2013 3:23 am    Post subject: Reply with quote
Personally, given the flaky tachometer readings, I'd start by checking the brown wire from the tachometer to the T3 terminal in the engine compartment and from the T3 terminal check the connection and the green wire from there to the #1 terminal at the ignition coil. Check connections, but also check for resistance variation as you wiggle the the green wires as you inspect for wire degradation. While you are there, try resistance tests on the coil itself -- I think resistance between the terminals should be less than 0.1 ohms, but check Hanes to be sure.
Ian89C4
PostPosted: Mon Oct 14, 2013 1:38 pm    Post subject: Reply with quote
Try replacing your negative battery cable. I had similar issues on my 911. After tearing down most everything I found that the negative cable had corrosion on the inside which did not allow the battery to ground enough which created a whole slew of problems.
Hope its a simple fix.
Cheers
Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala")
