Posted: Tue Aug 27, 2013 5:25 am Post subject: Wiring the SR10X Starter... terminal location is different.. |
Need to understand how to wire up the SR10X Starter in the 924 - The SR10X Starter has terminals to left and right of the center battery terminal.
The original Starter has terminals that are both on the left of the center battery terminal, so there is an upper and a lower wire/terminal.
[/URL]
So, does the upper wire go to the left or right of the battery terminal on the new starter?
Thanks in advance!!! _________________ 1980 924 NA 5 Speed |
Posted: Tue Aug 27, 2013 8:47 am Post subject: |
Probably the right one. Easy check is to put +12 volts (jumper cable from battery) on the Pos terminal, other lead to one of the bolt holes. Use a screwdriver blade to make a +12 volt connection to one of the two spade tips. The one that activates the solenoid and spins the starter motor is the correct one to hook up to in the car.
Chuck _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Sat Sep 21, 2013 3:31 pm Post subject: Top wire to Left Terminal - Bottom wire to Right Terminal |
The top wire goes to the Left Terminal on the SR10X and the lower wire goes to the Right Terminal.
The SR10X is smaller and lighter and bolted right in and does appear to have a higher RPM when cranking the engine.
