Tire Pressure...
ThomasJoseph315
Guest
PostPosted: Wed Sep 11, 2013 5:38 am    Post subject: Tire Pressure... Reply with quote
What are the stock pressures,.. what do people use?
I didn't know what it was cause all my tires where all over the map so I set them at the standard 32psi. I think this is kinda low for this car tho as I am getting rollover around corners I think.
!tom
PostPosted: Wed Sep 11, 2013 2:00 pm    Post subject: Reply with quote
For your car, I'd guess 29 psi.
Hayne's manual, page 195
924
165/?? R14 - 29 psi (steel wheels)
185/70 R14 - 26 psi ('79 and earlier aluminum)
185/70 R14 - 29 psi ('80 and later)
205/60 R15 - 29 psi
931
185/70 R15 - 29 psi front
185/70 R15 - 36 psi rear
924/931
205/55 R16 - 29 psi front
205/55 R16 - 36 psi rear
78 924 NA
5-lug
scm924s
PostPosted: Fri Sep 13, 2013 2:45 am    Post subject: Reply with quote
I initially set the Martini to 26 as recommended in the handbook, but low speed steering was so heavy, changed it to 30/29 more or less as the later cars with the same 185x70x14, made it much lighter.
1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold
