Posted: Fri Sep 13, 2013 9:59 pm Post subject: Need help with wideband O2 sensor connection |
I have an AEM wideband A/F gauge that I want to put on my 80 931. I want to replace the narrow band O2 with the wideband.
Which wire should I connect to wire that was feed by the narrow band? Brown? White? Other?
Instruction here:http://www.carid.com/images/aem/performance/pdf/aem-30-5130-installation-instruction.pdf
Thanks _________________ 1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP |
Posted: Sat Sep 14, 2013 12:08 am Post subject: |
| Quote: | WHITE – The WHITE wire should be c
onnected to the Lambda + input on the
EMS or the analog + input on a similar device.
BROWN – The BROWN wire should be connected to the Lambda – input or the
analog – input. If the EMS
or similar device does not have a – input, the BROWN wire
should be connected to a sensor ground. If
no sensor ground is available, the BROWN
wire should be connected to a power ground.
Note: The BROWN wire must be
connected in order to get correct
readings from the analog output. |
Looks like the White needs to go to the original sensor input for the toofah and the brown to ground (make sure it is a very good ground). _________________ Stefan
Posted: Sat Sep 14, 2013 12:13 am Post subject: |
Thanks
I did a search before posting but couldn't find anything, where did you find this quote? _________________ 1976 924 N/A ROW SOLD
1980 931S
Posted: Sat Sep 14, 2013 12:33 am Post subject: |
On the second page of the PDF you posted.
It essentially the same as the Innovative LC-1 I have (though I don't need the analog output) _________________ Stefan
Posted: Sat Sep 14, 2013 12:36 am Post subject: |
| fiat22turbo wrote: | | On the second page of the PDF you posted. |
.......  _________________ 1976 924 N/A ROW SOLD
1980 931S
Kenodog
Posted: Sat Sep 14, 2013 6:06 am Post subject: |
Why unhook the original O2 sensor ? Doesn't that throw the Lambda box into closed loop ? _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Posted: Sat Sep 14, 2013 6:24 am Post subject: |
The idea is to replace the original O2 with a wideband so you only have one, have a A/F gauge and you can still provide the require signal to the box. _________________ 1976 924 N/A ROW SOLD
1980 931S
