Sticky aux valve? orrrrrr
CorsePerVita
PostPosted: Tue Sep 10, 2013 12:03 am    Post subject: Sticky aux valve? orrrrrr Reply with quote
Alright, well, I'm driving the 924 (N/A) to work now pretty regularly and it's got a bit of a quirky idle I need to sort out that is driving me absolutely bonkers.
Sometimes the idle is smooth and where it should be. However, the vast majority of the time, the idle is around 500-600rpm and the car feels like it's going to die, but it doesn't. Drive it around a bit, let it warm up, and sometimes the idle will return to normal. I keep thinking, "what the f***?"
I've replaced vacuum lines and it doesn't seem to affect it. I also thought the idle adjustment screw had no bearing on it but that isn't the case at all. In fact, if you raise the idle, instead of 500-600rpm, it goes up to 650rpm, and then when the idle "returns" to normal, the "normal" idle is higher, say 1200rpm instead of 900 or 1000rpm.
This makes me think it's an aux air valve or something sticking. I'm not entirely sure since I'm not super amazing with CIS. If anyone has any things to check I am happy to start probing and checking sensors because it is driving me NUTS.
- 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
CorsePerVita
PostPosted: Tue Sep 10, 2013 5:32 am    Post subject: Reply with quote
Anyone? Bueler?
- 1999 Ducati 900SS
!tom
PostPosted: Tue Sep 10, 2013 11:51 am    Post subject: Reply with quote
I *THINK* i was having similar issues with my decel valve fully connected. It's now in circuit but with the vacuum line connected to atmosphere.
78 924 NA
5-lug
scriblz7
PostPosted: Tue Sep 10, 2013 3:15 pm    Post subject: Reply with quote
have you checked the warm and cold fuel pressures you are getting? i had a similar problem, and just needed to adjust the warm up regulator
Riley
79 924 n/a with gt body
15 VW GTI
scriblz7
Riley
15 VW GTI
CorsePerVita
PostPosted: Tue Sep 10, 2013 11:24 pm    Post subject: Reply with quote
Nope. Don't have a CIS tester. Ugh. Guess I need to just get one.
- 1999 Ducati 900SS
PostPosted: Wed Sep 11, 2013 12:22 am    Post subject: Reply with quote
Uh, yeah. Yeah you do if you're planning on keeping CIS-equipped cars around (the 931 and 924 daily's for example).
CorsePerVita
PostPosted: Wed Sep 11, 2013 12:47 am    Post subject: Reply with quote
Any recommendations on CIS testers that people have used, like and are reliable for a reasonable price?
- 1999 Ducati 900SS
PostPosted: Wed Sep 11, 2013 12:59 am    Post subject: Reply with quote
http://forums.pelicanparts.com/porsche-911-technical-forum/179746-diy-cis-tester.html
http://www.924board.org/viewtopic.php?p=350517&sid=3e2c2b277d56b560416417a1628016b3
http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=SAG33800&source=froogle&kw=SAG33800
http://www.ebay.com/itm/Master-Fuel-Injection-Pump-Pressure-Test-Kit-CISE-CIS-Metric-SAE-Free-Shipping-/200885133891
CorsePerVita
PostPosted: Wed Sep 11, 2013 1:16 am    Post subject: Reply with quote
DIY method seems easy enough. I have an extra CIS system laying around so I can make one from that. Great idea. Thanks man!
- 1999 Ducati 900SS
