spandelly
Joined: 26 May 2012 Posts: 23 Location: Manchester England
Posted: Sun Sep 01, 2013 10:01 pm Post subject: New project reverse light |
Hi folks got myself a new project car that's been laid up for ten years. So far I have only had time to give it a quick once over and check out a couple of things. I will start a proper thread once I have some decent pics. Anyroad the problem I have at the moment is the gearbox has been converted from auto to manual but it has the 4 speed box . Anyway the reverse light has never been connected and I cant find the wiring for it. Anyone know where the reverse light switch on an auto is?.
Theres a long list of other stuff to do mainly the fuel pump and a battery drain plus the ridiculously heavy clutch on top of getting it running. I have spent too much money this month so i'm doing the free stuff first.
I think the clutch may be down to a rusty cable and the fuel pump I know is knackered but the battery drain I have not had time to look into. The battery is checking out at 12v off the car and powered the windows when wired direct but as soon as I connect it to the car it drops to 9v and starts counting down a mv at a time but I dont know where to start with that really _________________ It could always be worse so don't worry about it and get the spanners out |
spandelly
Posted: Mon Sep 02, 2013 2:48 am Post subject: |
No ideas on the reverse light? _________________ It could always be worse so don't worry about it and get the spanners out |
staticsan
Joined: 19 Jan 2009 Posts: 450 Location: Sydney, Australia
Posted: Mon Sep 02, 2013 10:36 pm Post subject: |
The Haynes book should show you where the reversing light switch is. It has exploded diagrams of all the gearboxes.
Wade. _________________ '82 British NA - Which I think I've been very lucky with! |
spandelly
Posted: Tue Sep 03, 2013 4:03 am Post subject: |
Found it today its not on the gearbox it runs off the ignition stop switch on the gear selector. Found the wires taped up under the centre console so I will sort that this week. _________________ It could always be worse so don't worry about it and get the spanners out |
spandelly
Posted: Tue Sep 03, 2013 4:04 am Post subject: |
