Ole Petter
Posted: Tue Sep 10, 2013 12:26 am Post subject: Electric window left side does not work + fuel smell |
Hi
I am trying to help a friend to get his electric window working again.
He is English, so I have not seen this problem myself...
Maybe someone can help, it would be much appreciated!
The car is a 924 Carrera GT "938"
He found this:
1) My electric windows left side stopped working.
2) I check....no power is going to switch.
3) I ran power from right side to left side from right side switch......It worked.
4) So I decided to take a power source from a 25 amp fused supply, I put a 20 amp fuse in the lineto the switch.
5) It blew the 20 amp fuse, so I put a 30 amp fuse in. result nothing. Not blown fuse but no power to switch.
6) could i have blown the switch?.. or motor?
7) are these switches on a relay. if so where is it located?
Right side switches work Ok with power to both.
He also describes a fuel smell when he turns left! What can be the problem? He suspects a detoriated fuel return line? |
Kens_74_911s
Joined: 01 Mar 2011 Posts: 529 Location: Southern Pines , North Carolina USA
Posted: Tue Sep 10, 2013 1:47 am Post subject: post |
Probably a bad switch if you are careful you can take them apart and evaluate contacts or just get another switch.
Fuel issue may be a bad tank I was about ready to sell my 82 steel tank that looked great. When we removed it we found a section of the top had rusted through, probably from condensation. They can also crack on the top. That being said, he may want to check the return lines like you mention. Pull the cover on the inside where the fuel filler hose runs . All sorts of fuel and vent hoses in there. _________________ Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars |
!tom
Posted: Tue Sep 10, 2013 11:55 am Post subject: |
The fuel issue could be this. _________________ 78 924 NA
5-lug |
