tyfighter123
Posted: Tue Aug 13, 2013 7:02 am Post subject: Guess the horse power???? |
Ok so I finished up my rebuild back in April and put my breakin miles on it. Here is the list of mods
-Big valve kit
-Ported head
-Bored out to 87.5mm
-New Diamond pistons 9.5:1 compression
-New solid lifters from group buy
-Reground stage 1 integral cam
-Bursch 2.5" exhaust
I also lightened the rods and the flywheel.
The ignition and fuel systems are stock.
So after the first 2000 miles I put it on the dyno. I am at 4800 ft and it was about 90 degress outside any guesses on what the wrhp and torque were.................? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car) |
CorsePerVita
Joined: 25 Jul 2008 Posts: 1992 Location: Redmond, Oregon
Posted: Tue Aug 13, 2013 7:09 am Post subject: |
25hp!  _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
tyfighter123
Posted: Tue Aug 13, 2013 7:29 am Post subject: |
baawwwwhhhhh.......good one  _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Posted: Tue Aug 13, 2013 12:27 pm Post subject: |
Were you pleasantly surprised or mildly disappointed? _________________ erstwhile owner of just about every 924 variant ever made |
CorsePerVita
Posted: Tue Aug 13, 2013 12:38 pm Post subject: |
| ideola wrote: | | Were you pleasantly surprised or mildly disappointed? |
pleasantly disappointed and mildly surprised? _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
tyfighter123
Posted: Tue Aug 13, 2013 12:52 pm Post subject: |
mildly disappointed.....but hoping for more........... _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Posted: Tue Aug 13, 2013 12:56 pm Post subject: |
135BHP _________________ erstwhile owner of just about every 924 variant ever made |
tyfighter123
Posted: Tue Aug 13, 2013 1:01 pm Post subject: |
105 at the wheels _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Posted: Tue Aug 13, 2013 4:49 pm Post subject: |
So you have like 1HP more? you need to fine tune it.
What was the torque...got a graphic? _________________ Supercharger and EFI kits
https://www.the924.com |
Raceboy
Posted: Tue Aug 13, 2013 5:36 pm Post subject: |
Dynos are so different and hp depends on number of things. Going to 1/4 mila and doing a run there (with soft launch) gives you trap speed and knowing your cars weight (total, with you etc), the online calculators even give quite accurate result.
Did you verify engines AFR abd ignition advance? _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Tue Aug 13, 2013 6:28 pm Post subject: |
| Considering there's about a 35% loss through the drivetrain that's not terrible. What does the butt dyno tell you? |
Posted: Tue Aug 13, 2013 6:35 pm Post subject: Re: Guess the horse power???? |
| tyfighter123 wrote: |
The ignition Any fuel systems are stock.
That's part of your problem there. Any system that requires the air flow into the engine to move a plate for fuel to flow can't be good for power production. In know all the claims of K-jetronics ablity to support more power but flow is very important to power production. |
Raceboy
Posted: Tue Aug 13, 2013 7:10 pm Post subject: |
There is nowhere near 35% drivetrain loss on 924. It is more like 15% being RWD (~20% region on AWD cars) and also depends on MANY things, for gearbox example oil temperature, wheel bearings, tires etc etc.
Like I mentioned, check the mixture at WOT with WBo2 meter and verify that your base ignition advance is correct (10 degrees BTDC on Euro cars, dunno on US ones). If Euro vs US distributors have different advance curves, swap to Euro unit. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Posted: Wed Aug 14, 2013 12:15 am Post subject: |
Running at sea level would probably give you about 15% more hp, if you only take air pressure int account. Alltitude severly kills power on a n/a engine.
But thats the thing with roller dynos, the only thing you can actually compare with is a before-after run. Even things like tyre pressure will affect the results..
Get a stock 924 up on the same dyno, wih similar tyre setup, then you will have a reference to compare to.
Giving it some more sparkadvance and tuning the AFRs might get you some hp more. _________________ 1980 924 Turbo
tyfighter123
Posted: Wed Aug 14, 2013 12:24 am Post subject: |
Thanks for the replies. I started at 96 rwhp and we tuned it up to the results in the charts.
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
