ThomasJoseph315 Guest
Posted: Mon Jul 01, 2013 10:23 pm Post subject: |
Nope. _________________ erstwhile owner of just about every 924 variant ever made |
Ian89C4
Joined: 01 Apr 2011 Posts: 561 Location: North Carolina
Posted: Wed Jul 03, 2013 11:14 am Post subject: |
Not unless the car is doing only track work.
With ambient track temp the last time I was out at 120, my oil got upwards of 250*F.
Regular driving conditions will (should) not drive it that high. _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Posted: Wed Jul 03, 2013 5:07 pm Post subject: |
I want my oil as cool as possible. I been known to gas it from time to time... meaning,.. every weekend  |
Posted: Wed Jul 03, 2013 8:40 pm Post subject: |
Why would you want it as cool as possible, that will only cause wear on the engine and high consumption. Its better to have correct temperature(and viscosity), hence the thermostat on the standard oil cooling system.
I have driven a stock 125Hp car on track for many years without problem (looong stints aswell). If you aint running a tuned car or track car there is little to no point in doing this. Buy some quality oil instead. Especially if you have a us engine with less than 125 HP. _________________ 1980 924 Turbo
daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Fri Jul 05, 2013 8:21 am Post subject: |
Why not fit an oil temp gauge first so you know whats going on.
Also I have found with these motors that high oil temps go with high water temps, so if water is ok dont worry _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
Posted: Sat Aug 03, 2013 11:17 pm Post subject: |
If you are hell bent on an oil cooler check out B&M super coolers. They are relatively cheap. I had one on my turbo'd miata years ago. Keep in mind the price creeps up when you start adding in extra bits like AN fittings, adapter plate, oil filter relocation,thermostat, etc. _________________ 1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. |
