radio question
ltgland
Guest
PostPosted: Mon Jul 29, 2002 6:23 am    Post subject: Reply with quote
my radio now comes through from the door speakers (cleaned the contacts, what a difference), but it still does what it always did. After about 45 minutes, it just turns off. Anyone else have this problem or know how to PD it?
Guest
PostPosted: Mon Jul 29, 2002 2:06 pm    Post subject: Reply with quote
Possibly your radio has a thermal shutoff. If so, some things that could cause it to overheat would be speakers with a too low impedance and playing it too loud, maybe an incorrectly configured system.. External amp not wired correctly...
I should add incorrect voltage to the radio as another possible cause.
[ This Message was edited by: Smoothie on 2002-07-29 14:23 ]
Vince Ponz
Guest
PostPosted: Mon Jul 29, 2002 10:48 pm    Post subject: Reply with quote
It is a Porsche time to distance thing. The radio cuts out because you are driving too slow. If You would have driven faster the radio would not conked out.
45 min drive takes you 46 min it will cut out.
same drive done in 44 min and the radio will be fine.
It is the same with flats. Get home before it goes completely flat and then fix it. If it goes flat on the road most people complain.
Virinse
Tongue and foot in mouth
Vince Ponz
Guest
Virinse
Vince Ponz
Guest
Virinse
Vince Ponz
Guest
Virinse
Vince Ponz
Guest
Virinse
Vince Ponz
Guest
Virinse
Vince Ponz
Guest
Virinse
924 turbo
Guest
PostPosted: Mon Jul 29, 2002 10:52 pm    Post subject: Reply with quote
Dear God, we have a new record! Septuple posts!
ltgland
Guest
PostPosted: Tue Jul 30, 2002 2:32 am    Post subject: Reply with quote
nahhh.... Vince was having the "cookie" error message, I got it too and multiple posts
