In a serious bind...
nivekrs
PostPosted: Sat Apr 20, 2013 7:48 am    Post subject: In a serious bind... Reply with quote
While removing my fuel accumulator on my 1982 924 NA, I broke the pressure fitting which screws in to the accumulator. It's the end of the fuel line which comes from the fuel pump. I have found that Pelican Parts can no longer find that OEM fuel line, nor does and local parts store have anything close to that pressure fitting. I don't necessarily need the whole line with the fuel pump banjo fitting but I do need the accumulator pressure fitting. I could always somehow cut and splice the fuel line but I must find a fuel line with the correct pressure fitting. Can anyone help?
agfisher
PostPosted: Sat Apr 20, 2013 10:35 am    Post subject: Reply with quote
Where did it break? Got a picture?
1977 924 N/A Martini Edition
