p0rsche
Joined: 25 Mar 2013 Posts: 4 Location: Pittsburgh, PA
Posted: Wed Mar 27, 2013 11:54 am Post subject: '80 924 turbo won't idle - starts and stalls continuously |
Car ran well untill a few months ago. Began to start/stall a few times before eventually starting and running well. Found and repaired a minor fuel leak in the flexible fuel return line near the tank. Had to drain the tank to fix. Cannot get the car to run since the repair. Starts and stalls after 2 seconds - over and over again.
It will run (badly) if i continuously spray starting fluid directly into the intake. Any advice would be appreciated. _________________ Jeff
1980 924 Turbo |
Posted: Wed Mar 27, 2013 1:18 pm Post subject: |
Sounds like a serious fuel delivery problem of some sort. You need to start with a proper CIS test. If that checks out (warm + cold x system + control pressures, + leakdown), then you need to check fuel delivery (volume, flow, pattern, etc. at the injectors).
But before you do any of that, make sure the overboost cutoff switch didn't get inadvertently disconnected. To eliminate it as a culprit, I strongly recommend grounding that lead out until you complete the other diagnostics.
Recommended reading:
http://www.924board.org/viewtopic.php?t=35734
http://www.924board.org/viewtopic.php?t=28790 _________________ erstwhile owner of just about every 924 variant ever made |
p0rsche
Posted: Thu Mar 28, 2013 8:17 am Post subject: |
Thanks very much! I'm sure it will take me a while to get through all this. I don't have much free time.
I don't have a tester and may not be able to afford one. How much are yours? Are any other special tools needed for other tests? I have a good collection of standard tools.
I'm trying to decide if I should cut my losses. The car also needs the shifter linkage bushings replaced, a heater blower motor, a rear bumper and some exhaust work.
Thanks again. _________________ Jeff
1980 924 Turbo |
p0rsche
Posted: Sat Mar 30, 2013 9:19 am Post subject: |
So I bypassed the overboost switch and the car tried a little harder to run. It ran a bit longer (~3 sec). So I'm guessing the switch is at least a contributing factor to the problem. I'd like to check/replace all the vacuum lines next.
Where I can find a comprehensive list (with pictures) of all lines that should be checked/replaced?
Also, it smells like it might be running rich. Any thoughts? _________________ Jeff
1980 924 Turbo |
Posted: Sat Mar 30, 2013 11:57 pm Post subject: |
| p0rsche wrote: | | Also, it smells like it might be running rich. Any thoughts? |
Probably a vac leak for sure. DO NOT adjust the mixture until you eliminate the vac leaks. There are seven elbows at various locations which are all probably cracked and leaking. Two of them are very difficult to get to, down by the turbo itself. The others are fairly accessible. Then there are all the small 4mm lines, just replace those with silicone hoses. Check the intake gasket, throttle body gasket, injector bungs, etc. by spraying water (should cause a stumble) or carb cleaner (should cause it to race). I believe some of this is covered in the previous links, if not, there are tons of other posts, so some searching will help. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sun Mar 31, 2013 4:39 am Post subject: |
| ideola wrote: | | DO NOT adjust the mixture until you eliminate the vac leaks. . . |
. . .and test system and control pressures with a properly set up CIS tester.
Yes, you have to, and yes, the tool costs money. _________________ Toofah King Bad
p0rsche
Posted: Sun Jul 28, 2013 12:07 pm Post subject: Runs - Sort-of |
Update:
Fuel pumps are working and all small vacuum lines have been replaced with silicone. Other lines and elbows have not yet been replaced.
I can get the car to idle smoothly if I hold the metering plate down slightly. Otherwise it stalls quickly.
If I throttle-up, it will stall. If I throttle-up while pushing down on the metering plate I can get it to rev nicely.
I will continue to replace vacuum lines and elbows. Is there anything else I should be focused on?
Thanks! _________________ Jeff
1980 924 Turbo |
Posted: Sun Jul 28, 2013 12:28 pm Post subject: |
Have you tried turning out the idle air screw on the throttle body? Sounds like you are running rich, surprised it starts if so. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Sun Jul 28, 2013 8:24 pm Post subject: |
Have you purchased a CIS Tester and conducted the tests yet?????? _________________ erstwhile owner of just about every 924 variant ever made |
ptheskil
Posted: Sun Jul 28, 2013 9:05 pm Post subject: |
You are running lean. Pushing down the metering plate on the 931 increases the fuel flow rate. There are many problems which can cause lean running but only two causes : too much air or too little fuel. You are working on the too much air problem by chasing down vacuum leaks (any leak after the metering plate, not just past the throttle plate). To rule out fuel problems you MUST do the fuel pressure and flow rate tests - it is the only way to reliably diagnose CIS fuel delivery problems. Once you know the results of those tests you can systematically put things right. I suspect that your initial running of a few seconds is due to the additional fuel supplied by the cold start injector. You could spend a lot of money and time replacing things you don't need to if you take a "short cut" by not doing the CIS tests. _________________ 1981 931 series2 Euro spec |
