sciroccosteve
Joined: 16 Apr 2012 Posts: 215 Location: Rochester, NY
Posted: Sat May 26, 2012 6:56 am Post subject: rear side interior panel reconstruct? |
Hey now,
My interior rear panels have peeled back and away from the window. Has anyone come up with a way to reshape them nicely? _________________ 1979 924
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns |
Posted: Sun May 27, 2012 6:28 am Post subject: |
I've thought of replacing the cardboard backing with a different material. . .haven't got around to execution, tho. _________________ Toofah King Bad
sciroccosteve
Posted: Mon May 28, 2012 1:14 am Post subject: |
| Rasta Monsta wrote: | | I've thought of replacing the cardboard backing with a different material. . .haven't got around to execution, tho. |
I was thinking something along these lines as well. Any ideas on material to use? _________________ 1979 924
2000 V6 Passat
!tom
Posted: Mon May 28, 2012 2:01 am Post subject: |
Fiberglass? _________________ 78 924 NA
5-lug |
txjake
Joined: 17 Feb 2007 Posts: 395 Location: Oklahoma City OK
Kens_74_911s
Joined: 01 Mar 2011 Posts: 529 Location: Southern Pines , North Carolina USA
Posted: Thu Mar 07, 2013 7:32 am Post subject: panel repair options |
I have had some success clamping the panel face side down with the proper contour blocking from below etc. then brushing fiberglass resin on the panel. In really beat up areas you can pull some fiberglass matt apart and layer that in place. It does a pretty good job of stiffening things up to maintain the desired profile. I wouldn't do it where the backing is all the way through without putting some foil tape between the backer and vinyl. I suspect the vinyl could then be pulled and brush resin on opposite if needed to make a composite of sorts.
I have a 944 door card that looks pretty soft in one spot. I may work on that this way and post some pictures. The 944 door cards also fail where the power mirror switches attach, That area in F/glass puts back material needed for retaining screws to grab.
Working in ABS sheet is a challenge without vacuum forming equipment. Polystyrene sheeting is less expensive and takes to thermoforming well. I experimented with a sheet bought to fabricate a spoiler lip. It was a challenge to get the heat evenly distributed then and push the contour evenly. To much heat or pressure and it stretches to far and really won’t go back to the shape you were trying to get. I could see sheet material working with gradual bends maybe simplify the curves in the area that is shaped like an arm rest and where seat belt passes through. _________________ Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars |
