MikesCoupeGT
Joined: 18 Oct 2006 Posts: 474 Location: Ontario Canada
Posted: Tue Jan 22, 2013 4:16 am Post subject: Wiper motor cross reference |
Ok, so I have been able to determine that I have power all the way to my wiper motor. I also do not hear a thing when I put the wipers on in any setting. I think my motor is done!
That being said, looking to cross reference what other VWAG cars would use the same motor.
I am thinking
Rabbit/scirocco
Audi 5000/4000/CGT
944.
Anyone know for sure?
Thanks _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line |
Ozzie
Posted: Tue Jan 22, 2013 7:29 am Post subject: |
If you have a multimeter.
put it on ohms setting (resistance), lowest setting, and check the following.
the body of the wiper motor to -ve on batt, should be zero or close.
unplug the motor
31 to body of motor, zero or close
53 on motor to body of motor, very low, a few ohms
53b on motor to body of motor, low, a few ohms higher.
if you dont get these readings on 31, 53 and 53b then motor is faulty. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
Posted: Tue Jan 22, 2013 10:20 am Post subject: |
Newest unit I have found that will fit is 1988 924S. _________________ Toofah King Bad
MikesCoupeGT
Posted: Tue Jan 22, 2013 12:47 pm Post subject: |
Thanks guys;
Ozzie --> It was through using my multi-meter on that setting that I deemed the wiper motor faulty. But thank you. It did take me a try or two to get the multimeter working properly (batteries do help sometimes! LOL)
So if a 924s motor would fit, I may be able to use an early 944 wiper motor. Awesome. I will start my hunt for one.
Thanks again guys. _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
