to those who have added momo hub kit and steering wheel....
canyonblaster
PostPosted: Tue Dec 18, 2012 6:31 am    Post subject: to those who have added momo hub kit and steering wheel.... Reply with quote
i have a cool momo wheel to add. i have the correct hub kit and horn button for the toofah. questions are two:
1. my momo wheel has a modest amount of "dish", it isnt flat but it is shallow. will the wheel rim clear the turn signal and wiper control arms w/o a spacer?
2. can i use the stock oem cancel ring or do i need anything else?
thanks!
PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Daily Driver P cars: 2008 Cayenne GTS, 2013 Cayenne GTS
PostPosted: Tue Dec 18, 2012 7:00 am    Post subject: Reply with quote
I think the hub should have a pin to install in the bottom to provide the turn signal cancel.
On the depth issue, I would probably just pull the wheel and test fit it in place. Depending on your physical dimensions you may find you want a spacer to bring it closer to the chest to provide extra leverage, etc.
PostPosted: Tue Dec 18, 2012 5:03 pm    Post subject: Reply with quote
I would not bother changing wheel if I didnt move the wheel closer to me at the same time, that really transforms the driving position. From wheel to knee bash to excellent
My hub did have a return pin, but it didnt work. Not a problem to live without..
