MikesCoupeGT
Joined: 18 Oct 2006 Posts: 474 Location: Ontario Canada
Posted: Sat Nov 10, 2012 6:21 am Post subject: Quick question and background. |
So my goal with this 924 is to hit the track. Currently the car is running the stock brakes. I am looking to run the car at Watkins Glen in 2013 as well as a track near me, Calabogie Motorsports Park.
My question is, Am I going to hurt myself? Will the brakes stand up to a weekend of track driving. There will be times when I will let them cool off for a lap or two.
Just looking for opinions. _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
''19 Elantra GT N-Line |
Posted: Sat Nov 10, 2012 7:18 am Post subject: |
i think it depends on how many laps you do and how fast the circuit is and ofcourse how fast are you.
i've tracked the 924 NA with drums on the back on a not so fast circuit and i had no problems to do a few fast laps.
if you know how to work with those brakes i think they will not be a problem....if you dont..and use them too often and too hard...you will heat them up and they will fade. _________________ Supercharger and EFI kits
https://www.the924.com |
Posted: Sat Nov 10, 2012 7:52 am Post subject: |
I have had lots of experience with running a stockish 924 on track for several seasons, hunting down modern porsches
Ive ran my 924 for many many track days, from 2degC to 30+degC ambient temp. Running time between 15min to about 1hr stints, we drove 2 ppl in the car during those track days. No matter how hard we pushed the car the brakes never failed or faded once. This car were stock except for sticky R compunds tyres+lots of negative camber and of course a rebuilt/refreshed brake system and decent pads(Tried both Hawk Hp+ and carbotech xp8) and nice brake fluid.
I also have driven endurance racing with a team that drove a 924, with no name pads" we only got a couple hours before changing (no fade though). With nice ones they lasted looooong time.
So the trick is:
Refresh/rebuild your calipers, its almost free, and on this kind of calipers its VERY important that they can slide freely. Otherwise they will build up unnecessary heat in the pads. My recommendation is to run the combination of Hawk HP+ in front, "stock" brakes at the rear (its important that they are well adjusted and do not drag against the brake drum when they heat up and expand) and some good fluid, for example Motul RBF600. I removed my brake shields for some better air flow around the disk.
Trick number two:
Crappy braking technique can kill any kind of brakes. The trick is to brake hard and for a shorter time. Dragging the brakes for 200m before the corner is only gonna be hard on the brakes. So hard and short.
If you wonder anything about track driving a 924 just ask  _________________ 1980 924 Turbo
daniel
Posted: Tue Nov 13, 2012 7:56 am Post subject: |
A lot also comes down to the pads. I use Hawk DTC60 compound and find it just stands up to the strain. Also for a cheap upgrade fit drums from a Type 3 VW and calipers from a Audi 80. They bolt straight up. The only other mod I have made is to convert the cross split to a standard front and rear split and I also use a turbo master cylinder. _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Tue Nov 13, 2012 12:39 pm Post subject: |
Spend a few bucks at the junkyard and get yourself four wheel discs. IMO, the drums are not the biggest problem, it is the solid front rotors getting too hot. _________________ Toofah King Bad
skytrooper
Joined: 29 Aug 2007 Posts: 461 Location: Canandaigua, NY
Posted: Tue Nov 13, 2012 3:12 pm Post subject: |
Are you running it in Chumpcar ? Those are a few of the tracks for the 2013 season. _________________ Matt
1987 - 924S "Black Pearl"
1982 - BMW 633CSi
1984 - BMW 528e
1983 - 944 N/A "Blue Max" (Gone)
1981 - 931 "Scarlet Harlot" (Gone)
1976 911S Targa (Gone) |
MikesCoupeGT
Posted: Thu Nov 15, 2012 12:48 am Post subject: |
Hi matt;
No this is just my toy and track day car. I am going to be renewing my old membership to the Porsche Club of America (PCA) and taking part in the Zone 1 24 hours of Watkins Glen.
As for the Calabogie Motorsports Park, that is my local track so a day or two there will be for fun and to take out frustration of every day moron drivers. LOL.
Mike _________________ Cheers;
MikesCoupeGT
'76 924
'83 944
