Window problem electrics?
spandelly
PostPosted: Wed Jul 11, 2012 8:40 am    Post subject: Window problem electrics? Reply with quote
Hi folks my window on the passenger side only works when you press both buttons. Drivers switch and passenger switch dont know why any ideas fellas. Thanks for anything that might point me in the right direction.
It could always be worse so don't worry about it and get the spanners out
edredas
PostPosted: Wed Jul 11, 2012 2:21 pm    Post subject: Reply with quote
Sounds like the switches are assembled wrong.
On the passenger side, the switches are apart of the circuit. If they are assembled wrong, you'll end up with a variety of issues.
Simply take both switches apart and put them back together like this:
Edit: I realized that if you don't know what you're looking at, the switch may appear assembled correctly, when it isn't.
The top side with the Numbers is your reference point. Make sure that the contacts are placed just like the picture.
The Curled under parts of the contact switch not only act as a spring, they are in constant contact with the negative, and transfer it to the Passenger window. Put them in backwards and you have the wrong current running to the window, and it won't work.
When you have an issue like yours, I believe it's because one switch is right, and the other is wrong.
'84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
spandelly
PostPosted: Thu Jul 12, 2012 4:42 am    Post subject: Reply with quote
Thanks will have a look tomorrow
spandelly
PostPosted: Sun Jul 22, 2012 4:26 am    Post subject: Reply with quote
Yep it was the drivers side switch contacts the wrong way round.
Thanks a lot for that one saved much messing about.
edredas
PostPosted: Sun Jul 22, 2012 6:12 am    Post subject: Reply with quote
Glad I could help!
Gatornapper
PostPosted: Fri Jun 03, 2022 12:25 pm    Post subject: Reply with quote
My last post here may help as well........
https://www.924board.org/viewtopic.php?p=410195#410195
GN
'87 944 S, looks & runs like new - sold my sweet 931; '76 914 2.0 mostly restored; 2011 Porsche Cayman S in Meteor Grey, 3.4L, Softronics ECU tune 355+hp , PDK w/Sport Chrono. Got this thing for Porsche's.......
Gatornapper
PostPosted: Fri Jun 03, 2022 12:27 pm    Post subject: Reply with quote
