Pressure pot spray guns
924aussie
PostPosted: Tue Mar 20, 2012 2:55 pm    Post subject: Pressure pot spray guns Reply with quote
Pressure pot spray guns, has anyone ever used these even on a small spray job on a car ?
Nationwide autoshop has these type on special at $100
Spray Gun with 10l tank
Average air consumption 170-249 lpm
10 litre tank capacity
3 m hose
2.00mm nozzle
Looks a bit like this
http://t0.gstatic.com/images?q=tbn:ANd9GcTCCyWsG3JzQGGmGYrAghG2J7bs3XwdOCFFqQ6wl34qSvKzUIUV1w
green 924 .. 1980 rego 924PSH
1998 Mopar Neon ... sick
2003 Challenger / Montery 4WD
1995 Hyundai Scoupe ... sold
1998 Nissan Silvia ... sons back from OS he has taken it
BIG BLOODY MOTORHOME 300zx Sold
1980 Fire truck Sold
PostPosted: Tue Mar 20, 2012 8:12 pm    Post subject: Reply with quote
Geez a hundred bucks, its more than not a HVLP gun with a big paint cup.
if you ever want to spray big flake youll have to get a bigger nozzle!
924aussie
PostPosted: Tue Mar 20, 2012 10:34 pm    Post subject: Reply with quote
Its my understanding that you connect these things to a compresor ... presure them up, disconnect and take it to the task without the compressor, is that correct.
Alan
!tom
PostPosted: Wed Mar 21, 2012 2:27 am    Post subject: Reply with quote
I'd be surprised if you could get much paint out then.
The tank is 10 l in size, and the air consumption is ~ 200 l per minute.
78 924 NA
5-lug
PostPosted: Wed Mar 21, 2012 1:34 pm    Post subject: Reply with quote
Requirering a huge compressor.
v8carreragts
PostPosted: Thu Apr 12, 2012 7:16 am    Post subject: Reply with quote
The pressure pot is used for extended spraying. No need to stop and re-fill the cup. They are usually used in industrial production painting. It is connected to a low pressure line to feed the gun. It takes the place of the cup. You remove the cup and connect a hose from the pressure pot to the gun. This does not get disconnected so you can paint without a compressor.
I have a 2 quart pressure pot that you hang on your belt. If you spray with a conventional gun it gives you enough paint to do a complete coat without re-filling. However, I found that with HVLP one quart is enough to spray one coat on a large 4 door sedan.
84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Chevy Cruze
Kens_74_911s
PostPosted: Thu May 17, 2012 12:33 am    Post subject: PPot Reply with quote
A pressure pot has a separate regulator for the pot and it is connected to a supply air line all the time so you don't see a pressure drop as the paint level drops. I normally run one line and tee it off at the pot (2QT) continuing onto the gun since the pressure pot regulator is set less than at the gun. The pressure pot feeds paint to the gun and the gun atomizes the paint YES you need to be connected to a compressor. With the pot pressure dialed in you can throw down a very wet coat. It takes the load off your arm and wrist ( hood top and trunk panels) since the weight of the paint and pot is hanging off the gun on belt or other hand. It allows using some different angles sweeps since you don't have to wory about the reservoir.
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars
