joe b
Joined: 16 Sep 2010 Posts: 131 Location: McKinleyville, CA
Posted: Thu Jan 19, 2012 3:44 am Post subject: forgive me if this question is stupid... |
I might be getting my hands on some brembos and spindles/rotors from an '88 951 and I have been reading up on the conversion things necessary, and new strut housings are required as I can see
but I am not that familiar with most suspension details, especially not 944 suspension, but how would I acquire this? isn't it true that the later 944 strut housing doesn't come off?
would I be able to buy struts for an 88 951 and have them fit in a 931?
I just see the fact that the strut housings are required but never a way to source them! _________________ 1980 931 |
Posted: Thu Jan 19, 2012 9:43 am Post subject: |
88 setup will have wrong suspension geometry for a narrow body toofah. _________________ Toofah King Bad
joe b
Posted: Thu Jan 19, 2012 9:53 am Post subject: |
so you're saying spindles wouldn't fit from an 88? _________________ 1980 931 |
Posted: Mon Jan 23, 2012 11:07 am Post subject: Re: forgive me if this question is stupid... |
| joe b wrote: |
Not sure what you are asking, all struts "come off" but later 944 struts do not have a replaceable insert. In other words the shock absorber cartridge is not replaceable as it was in older cars. _________________ 87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold |
joe b
Posted: Mon Jan 23, 2012 3:58 pm Post subject: Re: forgive me if this question is stupid... |
| joecitizennn wrote: | | joe b wrote: |
Not sure what you are asking, all struts "come off" but later 944 struts do not have a replaceable insert. In other words the shock absorber cartridge is not replaceable as it was in older cars. |
yeah this is what i mean. for some reason in my head the cartridge became the same thing as strut housing _________________ 1980 931 |
Posted: Tue Jan 24, 2012 2:19 am Post subject: |
| joe b wrote: | | so you're saying spindles wouldn't fit from an 88? |
What I am saying is that the struts/spindles will bolt up, but because the assembly was designed to be matched up with a longer control arm from a "late offset" 944, the front end geometry won't be correct. Does this mean you couldn't obtain the correct alignment? Not sure. Ideola has done this I think with 968 parts, but I don't know how it came out.
On the insert issue, Joe is correct that the later struts were not designed to be rebuildable, but the enterprising folks over at Koni have designed replaceable inserts for late housings. . .some modification required.
Path of least resistance if you must have Brembos is to obtain these parts from an 86 951: struts, spindles, hubs, calipers for the front (no speedometer provision), and calipers for the rear. _________________ Toofah King Bad
joe b
Posted: Tue Jan 24, 2012 3:23 am Post subject: |
| Rasta Monsta wrote: | | joe b wrote: | | so you're saying spindles wouldn't fit from an 88? |
Path of least resistance if you must have Brembos is to obtain these parts from an 86 951: struts, spindles, hubs, calipers for the front (no speedometer provision), and calipers for the rear. |
thanks, I appreciate the clarification.
yesterday I did obtain the brembos for a pretty low price and the guy threw on spindles/hubs, so if I can make these work I will probably do so. either way its kind of a distant project since I'd like to finish engine work first. _________________ 1980 931 |
