LS1 924 build, first build shots
ls924
PostPosted: Thu Jun 16, 2011 12:31 pm    Post subject: LS1 924 build, first build shots Reply with quote
My ls1 924 project kicking off. First shots of big holes in firewall and tunnel, test fitting motor to work out if I can get away without having to use a bonnet scoop. Start of a long process but more to come soon.
http://imageshack.us/g/687/imag0037ni.jpg/
It will run an ls1, t-56 6speed, LSD IRS, 944 turbo brembos and control arms, fuchs wheels, dual brake MC floor mount pedal box, fully registered and complied for use on public roads in australia [/url]
thirdgenbird
PostPosted: Thu Jun 16, 2011 12:48 pm    Post subject: Reply with quote
pictures dont show.
17in caymans, koni yellow coilovers, hypercoil springs, kla solid upper mounts, 968 sway bars, kla drop links, kla strut brace, fidanza flywheel, dansk catback, wilwood front calipers, ss brake lines, e-codes, 944 duckbill, manual rack,momo steering wheel
the_mad_electrician
PostPosted: Thu Jun 16, 2011 12:59 pm    Post subject: Reply with quote
Show fine for me
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
ls924
PostPosted: Thu Jun 16, 2011 1:07 pm    Post subject: Reply with quote
yeah, just worked out how to link in the pics. this is my first post on a forum, long time lurker, first time member. I have taken inspiration from applebits build, main differences being i'm trying to get engine and gerbox s bit lower+ further back for weight and bonnet clearance, going manual (6 speed tremac) and maintaining the IRS rear end as i am going to mount a holden LSD up where the transaxle was and modify holden half shafts to fit. hoping for a bullet proof drive train by using all holden (chev) v8 stuff.
the_mad_electrician
PostPosted: Thu Jun 16, 2011 1:29 pm    Post subject: Reply with quote
I've been bouncing the idea of an engine swap for a while. I would probably go with an audi 5 cylinder and a 944 transaxle over a V8 swap though.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
ls924
PostPosted: Thu Jun 16, 2011 1:57 pm    Post subject: Reply with quote
engine weighs 30 or so kilo (60 pounds) more than the iron block 2 liter NA that I pulled out. it will sit about 3 inches further back than the old motor. the gearbox weighs 65 kilos but is sitting near as makes no difference in the middle of the car and as low as it can go without affecting ground clearance and the drivers seat (and me 85kg) will go about 2 inches further back till hard against the (removed) rear seat to make way for floor mounted pedals and new trans tunnel. The diff I'm putting in weighs a resonable amount and will include part of the rear cradle from the car it came out of. Adding a (road legal) half cage at the back and relocanting the battery to rear will hopefully offset the relatively minor weght increase at the front. won't really know till I get it on some scales but hoping to keep overall weight down and front to rear as close to 50:50 as possible. been lanning the build for several years now and chose chev over other considered options (924 engine turbo or superchaged, 944 turbo motors, 928 engines, audi v8, toyota iuz-fe). Have been told that there is a limit to power and torque that a porsche trans axle will handle and the strongest, which i'm told is a 944 turbo box will only handle about 500hp and in australia these boxes fetch stupid money (US/AU$9000+) and are hard to find.
ls924
PostPosted: Thu Jun 16, 2011 2:14 pm    Post subject: Reply with quote
one of my mates supercharged and turbogharged his alfetta GT 2L. here is him testing it at the track with my car before the engine swap (original 2L, 4 speed and drum rear brakes) in car footage shot inside the porsche
http://www.youtube.com/user/buzzedo1#p/a/u/2/ULW0_mEaThY
his engine cost more than I am planning on spending on my entire build
Andrew NZ
PostPosted: Thu Jun 16, 2011 4:48 pm    Post subject: Reply with quote
It'll be interesting to see how this works out. I often wondered why applebit didn't take your appoach with the rear end - it should handle much better than a live rear axle.
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
macBdog
PostPosted: Fri Jun 17, 2011 11:43 am    Post subject: Reply with quote
Nice start, reminds me of mine:
I am in QLD too btw.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
PostPosted: Fri Jun 17, 2011 8:36 pm    Post subject: Reply with quote
just curious whether you have got project approval through QLD transport yet, from questioning a few engineers there's a 3:1 multiplier on N/A power to weight ratio, so that would eliminate putting a 5 litre engine in a 1 tonne car ??
have they relaxed the laws recently? or are you an engineer yourself?
btw
hope the project works out too...
stu
PostPosted: Sat Jun 18, 2011 9:21 am    Post subject: Reply with quote
some huge pictures you have there.. looks awesome though.
AppleBit
PostPosted: Sat Jun 25, 2011 2:42 pm    Post subject: Reply with quote
LS WHAT?!
Your crazy... Anyone that puts an LS engine in their.. err, wait... nm
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
Tas931
PostPosted: Thu Jun 30, 2011 4:18 pm    Post subject: Reply with quote
Were you from Tassie?
ls924
PostPosted: Mon Jul 04, 2011 12:51 am    Post subject: Reply with quote
yeah, from hobart, thats where car is currently
Tas931
PostPosted: Mon Jul 04, 2011 11:13 am    Post subject: Reply with quote
Sweet as, i'm from Devonport.
So you come back every now and then and work on the ol girl?
Know many people around down here with them? i have seen 3 Na's one up here and one on the highway at longford and a white one driving around up the lakes.
