Engine breather
Andrew NZ
PostPosted: Tue Aug 23, 2011 11:47 am    Post subject: Engine breather Reply with quote
Hi, I helped a mate fit an oil catch tank to his 2.0L NA race car over the weekend, and then when thinking about it afterwards realised I might have screwed it up!
We used a smaller diameter tube than the original (about 9mm id), so I'm scared I might have created too much ressitance in the breather now. How critical is the size of the breather on these engines?
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
daniel
PostPosted: Tue Aug 23, 2011 12:01 pm    Post subject: Reply with quote
9mm ID should be fine for a crank case breather, did you delete all the charcoal canisters and other associated crap??
1989 944 Cabriolet
Andrew NZ
PostPosted: Tue Aug 23, 2011 12:16 pm    Post subject: Reply with quote
All it had before we started was a hose going straight from the block to the air cleaner.
Andrew
1977 RX924 race car
