tuf-924
Posted: Sat Apr 23, 2011 11:03 pm Post subject: Airflow meters????????????? |
I have seen some air flow meters that have an electrical plug on it I think it is a blue plug I was wondering what that was for?? And could I use that part still for one that has no plug since mine is #### and can't find a decent airflow meter that is like mine without the plug [/img] _________________ Vass... |
Ozzie
Posted: Sun Apr 24, 2011 6:22 am Post subject: |
Early 924 had a switch which activated the fuel pumps when lifted.
this was done away with the newer fuel pump relay setup.
later 924 had a supplementary start valve on the fuel dissy which ran off a thermo switch in the coolant line.
very likely the early air meters will fit later models. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
tuf-924
Posted: Sun Apr 24, 2011 8:20 am Post subject: |
Ah ok so it should still work? _________________ Vass... |
Ozzie
Posted: Mon Apr 25, 2011 2:24 pm Post subject: |
Depends on the your year model _________________ Porsche 924 1984 (UK import) NA
