gegge
Posted: Fri Apr 15, 2011 9:01 pm Post subject: Re: Heard of 123ignition? |
Really cool idea, to bad its so expensive. Gives med a lot of ideas of what could be done. Could need alot of time on the dyno though  _________________ 1980 924 Turbo
Posted: Fri Apr 29, 2011 9:14 am Post subject: |
I wonder if there are any reliability reports? Given what we've seen with the UT-CIS, I wouldn't want to be their guinea pig... _________________ erstwhile owner of just about every 924 variant ever made |
gegge
Posted: Fri Apr 29, 2011 6:15 pm Post subject: |
I have done some research and all clients seems happy. The problem is that there is no plug-n-play. You have to modify the 924 distributor maybe even cut and and weld. The 924 axle is 12,40mm in diameter and very long with a unique gear. _________________ Carl Fredrik Torkildsen
Martijnus
Posted: Sat Apr 30, 2011 3:45 am Post subject: |
my experience with 123 isn't that good, but those weren't programmable.
I find them a lot on english cars and you can set several curves at those, but it's hard to get them running properly in all areas, so we ditch the units and replace with good stock ignitions. Problem solved.
Doesn't mean those in the link aren't good  _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
gegge
Posted: Tue Dec 10, 2013 5:48 am Post subject: |
Cross reference to Carrera RSRs thread
Mittelmotor is running 123ignition in a GTC/GTS with 343 hp:
http://www.924board.org/viewtopic.php?p=355264 _________________ Carl Fredrik Torkildsen
