Performancefuel rail for us?
Shurick
PostPosted: Fri Jun 03, 2011 12:28 am    Post subject: Performancefuel rail for us? Reply with quote
There were several references across the board that mondeo fuel rail fits right on our engines.
Found this on ebay and got excited http://cgi.ebay.com/ebaymotors/OBX-High-Flow-Fuel-Rail-00-04-Focus-Zetec-ZX3-ZX4-ZX5-B-_W0QQcmdZViewItemQQhashZitem25642a58abQQitemZ160594286763QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Will it fit?
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Fri Jun 03, 2011 12:43 am    Post subject: Reply with quote
Looks like a nice piece. Who's going to gamble a Benjamin to see if it actually works?
Shurick
PostPosted: Fri Jun 03, 2011 1:03 am    Post subject: Reply with quote
I'll try if I'll find an affordable FPR for it.
WBR, Shurick
'86 924S -- R.I.P.
PostPosted: Fri Jun 03, 2011 2:19 am    Post subject: Reply with quote
http://cgi.ebay.com/ebaymotors/WEAPON-R-UNIVERSAL-FUEL-PRESSURE-REGULATOR-958-111-101-/180647444214?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a0f6d3ef6
I'm using this one. Works well so far. Should fit on that rail.
PostPosted: Fri Jun 03, 2011 2:38 am    Post subject: Reply with quote
fiat22turbo wrote:
PostPosted: Fri Jun 03, 2011 2:46 am    Post subject: Reply with quote
I use a Bosch MSD-2222 one from Summit Racing..
Has worked fantastic for 2 years. It isn't fancy colored though.
CorsePerVita
PostPosted: Sat Jun 04, 2011 10:33 pm    Post subject: Reply with quote
I need to figure out a way to mount a .... oh wait
- 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Thu Jul 14, 2011 12:04 pm    Post subject: Reply with quote
Stefan, how is your fuel rail secured?
Euro924S2
PostPosted: Sat Jul 16, 2011 9:24 am    Post subject: Reply with quote
Group buy??
eBay item number: 350464254150
This is the fuel rail I'm using - works great, no leaks. Only 2 things are; 1) only 1 port so ideally needs a second port to allow through flow of fuel keeping it cool and equalising the pressures better at high injector duty cycles and 2) spacing is out by a couple of millimetres - but nothing that creates a problem!!
I think you one you showed is off the same engine so should work well and appears to have 2 ports - bonus!!
UK spec '83 N/A with 931 motor with Eaton MP62 'charger @ 15psi. EFI - 565cc inj. Standalone Adaptronic ECU. 951 FMIC. Ally rad. Twin throttle. Recirc valve. Custom manifolds and CAI. 232bhp
PostPosted: Sat Jul 16, 2011 10:02 am    Post subject: Reply with quote
Mine is attached to the aftermarket throttle bodies. Built a bracket to hold the FPR in place (which needs to be redesigned, but I digress)
On the mockup head that I'm working on (to adapt EFI to the stock head and intake manifold) I machined the stock pockets to fit the Bosch injectors deeper into the pockets.
To hold the rail in place, I'm building a pair of brackets that mount to the upper manifold mounting bolts and attach to the fuel rail I scavenged from a Turbo-Dodge project. Will probably need to machine the holes in the brackets a little longer side to side to allow for slight misalignment of the injector pockets.
The Rails I'm using are available from Turbosunleashed.com or FWD-Performance.com OR you could buy your own rail blank and machine it to fit however you'd like.
PostPosted: Sat Jul 16, 2011 10:07 am    Post subject: Reply with quote
There's also this:
http://cgi.ebay.com/ebaymotors/OBX-Hi-Flow-Fuel-Rail-Dodge-Neon-SRT-4-03-04-SRT4-RED-/160603768487?pt=Motors_Car_Truck_Parts_Accessories&hash=item2564bb06a7
The Neon and older 2.2/2.5L equipped cars use the same bore spacing as each other and also are within a millimeter of the Ford's described earlier.
