tbirdguy
Joined: 26 Jul 2010 Posts: 1 Location: Coshocton, Oh. U.S.A.
Posted: Wed Jul 28, 2010 10:07 am Post subject: Coil Resisters |
I have a 1977 that has the two coil resisters. I have noticed that they get extremely warm, even to the point of being hot while the engine is running. Is this a normal situation? I know that a typical resister will heat up somewhat, but this seems a little extreme to me. The engine lost it's spark at one time, but after they cooled down the spark returned and the engine ran fine although they began heating up again. Does anyone know what the damage that could be caused if they were bypassed? Or, could I use another coil in this system that requires no resistance? _________________ Owner, 1977 Porsche 924 Martini Rossi Championship Edition |
Posted: Wed Jul 28, 2010 10:26 am Post subject: |
I believe you can dump the resistors and get a Bosch red coil. . . _________________ Toofah King Bad
the_mad_electrician
Joined: 16 Nov 2009 Posts: 1073 Location: Central Georgia
Posted: Wed Jul 28, 2010 10:56 am Post subject: |
I have a 77 and it does not have resistors. The car was like that when I bought it and it works fine, it probably has the coil Rasta is talking about because it is a Bosch. _________________ 81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6 |
!tom
Posted: Thu Jul 29, 2010 5:52 am Post subject: |
Removing a ballast resistor will shorten the life of your coil. _________________ 78 924 NA
5-lug |
Posted: Thu Jul 29, 2010 6:29 am Post subject: |
. . .unless it is a hot coil designed to run on 14v. _________________ Toofah King Bad
StienbargerR
Posted: Thu Aug 12, 2010 6:19 am Post subject: |
alright, so now I have the same problem. I've got a 78 with the coil resistors. After replacing my starter, and trying to start it, the driver's side ballast resistor cooked. It literally started smoking and was really hot. Is this a symptom of something else? And, if I go to remove the resistors, can I just essentially pull it out and connect the wires?
Ryan
ps- The car will not start also. I had it running fine just a week ago. Im thinking it is not getting spark because of said ailment. _________________ 1978 924 NA
tyfighter123
Posted: Fri Apr 01, 2011 4:44 pm Post subject: |
I have the same problem Im trying to start my car for the first time on the new engine. I had spark for a few seconds and then it went away. The resistor on the right hand side got really hot and there was a little smoke that came from it. Any suggestions"? _________________ Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car) |
Posted: Sat Apr 02, 2011 3:28 am Post subject: |
Just a thought, but maybe replace the resistors?
They should be labeled on the side as to their rating. _________________ Stefan
