very faint hissing noise from back of engine
Duncan
PostPosted: Thu Mar 31, 2011 6:34 am    Post subject: very faint hissing noise from back of engine Reply with quote
I hear a very faint hissing noise after my engine shuts down, like very soft from the back of the engine... It lasts a couple of minutes.
Any idea what this could be?
Cheers,
Duncan
1983 NA Alpineweiss since 2001
Peugeot 205 Generation
PostPosted: Thu Mar 31, 2011 6:45 am    Post subject: Reply with quote
Vac leak?
Coolant leak? Perhaps a pinhole leak in one of the heater core hoses, or head gasket at back of head?
PostPosted: Thu Mar 31, 2011 7:06 am    Post subject: Reply with quote
Did you check for snakes?
Duncan
PostPosted: Thu Mar 31, 2011 7:07 am    Post subject: Reply with quote
Yes I did. No snakes I am aware off.
!tom
PostPosted: Thu Mar 31, 2011 7:13 am    Post subject: Reply with quote
Brake booster (and associated plumbing)?
78 924 NA
5-lug
Duncan
PostPosted: Thu Mar 31, 2011 7:17 am    Post subject: Reply with quote
Thanks for all responses,
I would like to stress it occurs after shutdown.
Ozzie
PostPosted: Thu Mar 31, 2011 8:06 am    Post subject: Reply with quote
only fuel and coolant stay pressured after shutdown
Its AUTO and its BLACK
Montego Black on black/red
Lovecake
PostPosted: Thu Mar 31, 2011 9:54 am    Post subject: Reply with quote
I had this hissing problem, and several others (very loud tappety noise at start up, deep warbling/rattly noise at around 2k rpm). Turns out the nuts holding the exhaust manifold to the head had come loose (the front one had fallen off ). Anyway, replaced/retightened them all and these noises, including the hiss, disappeared. Might be worth a try.
'68 VW bug
blue 1979 924 N/A (wounded/parts car)
red 1982 924 N/A
PostPosted: Thu Mar 31, 2011 11:38 am    Post subject: Reply with quote
What about the brake booster?
mikebola
PostPosted: Thu Mar 31, 2011 11:49 am    Post subject: Reply with quote
That's a good option. The brake booster in my MG used to hiss. The thing is it was really obvious it was the booster and not the engine.
proud owner of a 1979 924 Sebring Edition with a 931 trans that looks horrible but somehow runs...
Duncan
PostPosted: Thu Mar 31, 2011 4:17 pm    Post subject: Reply with quote
Can you explain to me how the brake booster can hiss?
The moment the engine stops the vacuum drops, I would think.
Or am I missing something?
I never focused attention on the brake booster, but will do that next time.
Cheers,
Duncan
PostPosted: Thu Mar 31, 2011 8:25 pm    Post subject: Reply with quote
There should be a check valve in the line to the brake booster so that it maintains vacuum regardless of what's going on with the engine...otherwise, you would lose brake assist when you were at WOT...
PostPosted: Fri Apr 01, 2011 1:00 am    Post subject: Reply with quote
Yep, check valve. I can make my booster line hiss by wiggling the hose in the rubber fitting at the booster.
Dan, I chuckled a bit thinking of all the times I have been on the brakes at WOT!
PostPosted: Fri Apr 01, 2011 1:04 am    Post subject: Reply with quote
Heheh, yeah, I probably could have been a bit clearer about what I meant there...
PostPosted: Fri Apr 01, 2011 2:29 am    Post subject: Reply with quote
Coolant hoses going to the heat exchanger or one of the other coolant hose connections along the line there in the back..
