200sx turbo SR20 engine conversion
tuf-924
PostPosted: Sat Jun 25, 2011 5:32 pm    Post subject: 200sx turbo SR20 engine conversion Reply with quote
Ay guys I'm sick of the k-jetronic in my engine was thinking maybe an engine conversion would be pretty sweet and the sr20 turbo sounds like a good idea, anyone know if its possible?
Vass...
the_mad_electrician
PostPosted: Sat Jun 25, 2011 7:56 pm    Post subject: Reply with quote
Anything is possible, its all about how much do you want to spend.
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
PostPosted: Sun Jun 26, 2011 12:10 am    Post subject: Reply with quote
why not buy a 200sx then? its newer...can have AC...ABS..airbags..etc.
PostPosted: Sun Jun 26, 2011 1:21 am    Post subject: Reply with quote
I'd like to see it. SR20 turbo is a great powerplant.
tuf-924
PostPosted: Sun Jun 26, 2011 8:10 am    Post subject: Reply with quote
I love the look of the 924 if I can make it a massive sleeper I would love it even more.
It's either sr20 conversion or just put a megasquirt which would be easier I'm sure
Vass...
PostPosted: Sun Jun 26, 2011 1:10 pm    Post subject: Reply with quote
Stock driveline will not cope, so factor that into equation. Helps if you can weld, also get half cut and consider complete driveline and suspension replacement with new mounts to frame rails and shorten/lengthen driveline to suit distance from diff to gearbox(if using front mounted setup) this will give you an updated suspension setup at the same time
