85 944?
the_mad_electrician
PostPosted: Wed Jan 26, 2011 9:29 pm    Post subject: 85 944? Reply with quote
Is there a way to tell a 85 from an 85.5 by looking at it? There's an 85 944 on craig's list for 500 and I want it for a disk break conversion but it does say if its a 85 or 85.5
81 924 N/A
2004 Ranger "Edge"
2005 Mazda 6
9xx
PostPosted: Wed Jan 26, 2011 11:25 pm    Post subject: Reply with quote
'85.5 = oval dashboard, early '85 = classic square dashboard
Mikko
All gone: 931 '82 Alpine White, original option "220" G31 with LSD + 3 x 944
moorepower
PostPosted: Thu Jan 27, 2011 11:11 am    Post subject: Reply with quote
Wouldn't either one work for a 5-lug/disc brake conversion? The wheel offset didn't change until '87.
Dan.
'88 924S-LE (Luddite Edition)
Manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5mm torsions, 26.8/20 sways
Feltron
PostPosted: Thu Jan 27, 2011 12:56 pm    Post subject: Reply with quote
The wheel offset changed because of the ABS in '87 and I think the trailing arms changed in '85.5 because all the "How To"s for the 5 lug say be sure to get '85 and earlier. When I bought the parts for mine I got em off a '84 and everything just bolts right on no problem at all. Actually this weekend I'm going to finish bleeding it.
moorepower
PostPosted: Thu Jan 27, 2011 1:15 pm    Post subject: Reply with quote
Hmmm, I didn't know they changed the trailing arms in mid '85. Interesting.
Anyway, yeah, the dash is the giveaway. If it looks like your 924, then it's an early 85. If it looks way more up-to-date then it's 85.5.
Dan.
Feltron
PostPosted: Sun Jan 30, 2011 2:00 pm    Post subject: Reply with quote
http://www.924board.org/viewtopic.php?t=27357
Just making sure I wasnt lying, yea they switched trailing arms and a-arms mid way through '85.
Also to OP I used this guide for the early parts of planning and sourcing parts for my upgrade, I recomend reading it.
