I have totally fouled up this time
chad-tanner
PostPosted: Thu Jan 06, 2011 12:31 pm    Post subject: I have totally fouled up this time Reply with quote
I have totally fouled up this time.I was installing my front cross member(the part that bolts to the frame,that the a arms swing on).I have over torqued the nuts, stripping the threaded studs,and,or nuts.The nuts will not tighten or loosen,they just spin round,and round
I am so sick that this happened!! It's my fault for using air tools,and I'm so disappointed in myself!
Has anyone every had to replace,or maybe know how I could replace the studs?
77.5 Porsche 924/4.9L cadillac swap
Inspector: These brakes look completely inadequate.
Burt Munro: Well, I'm planning on going, not stopping.
PostPosted: Thu Jan 06, 2011 1:41 pm    Post subject: Reply with quote
Are you sure the stud is not turning?
chad-tanner
PostPosted: Thu Jan 06, 2011 2:15 pm    Post subject: Reply with quote
Thats what I thought at first,which is just as heartbreaking,but no I put an open-end wrench on it,and watched the nut turn on the stud.
PostPosted: Thu Jan 06, 2011 2:28 pm    Post subject: Reply with quote
Dremel tool buzz cut and off with the nut by cutting the stud.
chad-tanner
PostPosted: Thu Jan 06, 2011 2:33 pm    Post subject: Reply with quote
Thats great,and there are plenty of other easy ways for cutting off the stud.However,whats the best way to replace it? "it's all enclosed in the frame.
PostPosted: Thu Jan 06, 2011 5:19 pm    Post subject: Reply with quote
Cut it out and weld in a new piece. Take a breath, and get it done. No use to beat yourself now.
chad-tanner
PostPosted: Fri Jan 07, 2011 11:20 am    Post subject: Reply with quote
You're right,the show must go on! I refuse to let this project beat me!
I just finshed cutting the studs with my torch.I have plenty of things to work on before I get back to fixing that catastrophe!
9XX Girl!
PostPosted: Fri Jan 07, 2011 7:59 pm    Post subject: Reply with quote
you have learnt a valuable lesson here. Stick to hand tools
924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY
PostPosted: Sat Jan 08, 2011 3:19 am    Post subject: Reply with quote
Yesterday whilst grabbing a big electric drill with
a 1/2 exstension to chuck it up & stick sockets on
to remove lugnuts. I have a 3/8s one formy dewalt cordless.
I was thinking of this post there was another guy who did the
the same damage on a different part though.
