bmc65 Guest
Posted: Mon Jun 24, 2002 9:10 am Post subject: |
| I have a 79 924 that I drove from ohio to south carolina ran great the only problem is it don't start when its hot.? But if I spray ether in the air filter it starts up. Starts right up when its cold no problem. |
Smoothie Guest
Posted: Mon Jun 24, 2002 9:34 am Post subject: |
| Y'all been through the FAQ [Technical]? Try lookin' there for "Why won't my car start when it's warmed-up?" and "[ Hot Start Problem Fix ]". |
Joes924 Guest
Posted: Mon Jun 24, 2002 3:20 pm Post subject: |
| Yup hes right thats where your answer lies the holly FAQtech. |
ltgland Guest
Posted: Mon Jun 24, 2002 4:41 pm Post subject: |
doesnt start?
does it crank, or just click?
if it cranks, its the "hot start" listed in the FAQ, low pressure in the fuel system.
If it doesnt crank, then you suffer the same problem as me. From what I have been ready, this is from old engine to chassis grounds (I now have 4 grounds, 2 on one side of the coil, 1 on the other, and 1 to the battery ground post). Mine is also possibly a gummed up starter or pokey solenoid. |
JvGinPDX Guest
Posted: Mon Jun 24, 2002 5:49 pm Post subject: |
| Look in the technical section and the FAQs. They nention installing a switch that turns on the electic fuel injector. It solves the no hot start problem. It worked for me...... |
bmc65 Guest
Posted: Tue Jun 25, 2002 12:17 pm Post subject: |
I have put on a new fuel pump and a thermo time switch now if you hold it half throttle it will start hot most of the time but still not right. And I also have a problem with the slop in the shifter hard to shift does any one know how to fix??
thanks bill |
larso Guest
Posted: Thu Jun 27, 2002 5:52 pm Post subject: |
| Well if you hold it half throttle, how does it react once it starts? does it help if you keep the throttle up once it's started, or does it help if you kickly punt the peddle and let it flick back? If it helps to punt the pedal and let it come back fast, you have a too lean situation. If it helps to keep the pedlle held down now matter what, then its a too rich situation. Start from there, it's probably a too lean situation, so to get it started try playing with the peddle like a tap dance...tap it down back and forth until the car starts to run better. I find it always helps to tap the peddle, once the car is trying to stay running... holding it down makes it worse if done constantly. |
larso Guest
Posted: Thu Jun 27, 2002 5:56 pm Post subject: |
| As for the shifter problem, take off the boot and inspect things. Wiggle the shifter around. You can easily tell if its a bushing problem, or a simple worn out metal problem. If the stickshift wiggles around and you see movement, and putting tape aroudn the parts (to simulate a bushing ) helps...then you've found your problem. I think that you have a snailshell tranny, since your car is 79, but not sure...USUALLY the problem is always the bushings at the rear, hard to get, universal joint. In the Audi trannies, the problem is always at the EASY TO FIX location...and is a metal to metal problem. |
Posted: Thu Jun 27, 2002 10:22 pm Post subject: |
Welcome to the forum. Read the Tech Section. Read the FAQ. Use the Search function. All are linked above.
silveroldie Guest
Posted: Mon Jul 01, 2002 10:54 am Post subject: |
| My 82 starts hard but it starts by letting the pumps run for several seconds, cranking it and if it fires, immediately crank it again and it starts like a champ with throttle about half. Mine actually acts like the timing is too advanced because it cranks hard. So far, it has always started. |
