Stripped valve cover bolts
mgatlag
PostPosted: Mon Oct 25, 2010 2:30 am    Post subject: Stripped valve cover bolts Reply with quote
Today I am tracking down an annoying oil leak and noticed that 2 of the threaded holes for the valve cover are stripped. This metal is very thin already so re-tapping to a larger size doesn't look possible. Is there something out there that will fix the threads that are stipped in the head? I've read on the board about something called Permatex? Will that work?
I also noticed that one of the exhaust manifold studs just spins in the head . So it looks like I have the same issue with that hole too.
Michael
'77 1/2 924 N/A- 5 speed Audi box
'04 Ford Taurus - gone!!
'92 Jeep Cherokee Laredo - gone!!
Porsche... better than tea with Miss McGill
(Slap Shot)
!tom
PostPosted: Mon Oct 25, 2010 9:17 am    Post subject: Reply with quote
Permatex is a brand of a gasket material.
You're looking for a threaded insert for restoring threads. Heli-coil is one brand, there are many other similar products out there.
Basically, you re-tap for a slightly larger size (usually a non-standard size), and screw in an insert, which results in a restored thread of the original size.
If you really didn't have any extra room, you could try your own technique. You might be able to line the hole with JB Weld, then drill and tap that to the correct size. As this is just holding the valve cover on, it's not a critical part, so this technique may work sufficiently.
78 924 NA
5-lug
PostPosted: Mon Oct 25, 2010 11:51 am    Post subject: Reply with quote
agreed, the two part aluminium epoxy that you can get would probably satisfy the job,
BTW they are supposed to be studs, not bolts...
PostPosted: Mon Oct 25, 2010 12:13 pm    Post subject: Reply with quote
Epoxies have their uses but IMHO this is not one. Do the job properly with a SS thread insert. Helicoil, Permacoil, Recoil, Timesert are common brand names, available at your local industrial / bearing shop, or ebay. Get the kit with tap, application tool and enough inserts to do all the holes. Same with the manifold holes, use a M8x1.25. However will probably need to remove manifold first. I`ve done all mine and have a considerably stronger thread with no chance of ever stripping again.
Allan @ DTA wrote:
mgatlag
PostPosted: Mon Oct 25, 2010 1:57 pm    Post subject: Reply with quote
The auto parts store does carry helicoils and I've read up on them quite a bit so I think I'll give that a try tomorrow. Probably going to get all new studs too because some of mine are bolts and some are studs.
I'll also be trying to track down a pretty good oil leak too. All I know right now is the exhaust side of the engine is pretty covered. Which in turn means the driveway is too....
Michael
(Slap Shot)
PostPosted: Mon Oct 25, 2010 11:27 pm    Post subject: Reply with quote
yep sorry, didn't see the manifold stud issue, that needs a helicoil...
S.
