Any insight from you guys? 944 clutch hydraulics issue.
Slam
PostPosted: Tue Oct 26, 2010 2:28 am    Post subject: Any insight from you guys? 944 clutch hydraulics issue. Reply with quote
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/571016-need-advice-clutch-gurus.html
Thanks for looking!
'84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably
PostPosted: Tue Oct 26, 2010 3:55 am    Post subject: Reply with quote
check out the mount of the master cyl...the one from the pedal.
maybe the firewall has cracked or weakened and you've got cyl movement.
maybe you didn't tighten the cyl properly and it moves.
The firewall is quite flexible there.
I've made a reinforcement aluminium plate to help the fiewall
