Really stupid question : Tires
owenexile
PostPosted: Sun Oct 17, 2010 8:10 pm    Post subject: Really stupid question : Tires Reply with quote
I feel stupid for asking this , but what size tires do i have? Since this will be my first time Changing Tires and a friend told me i should give him the sizes and hell do it for me at "friends/family" rate if i visit him again , he works at a tyre/suspension shop.
xxx/xx/xx?
Thanks
924 1982 N/A
For some reason theres always a earth problem somewhere with this car...
germ924
PostPosted: Sun Oct 17, 2010 8:19 pm    Post subject: Reply with quote
well. your a noobie for sure, but we starte this way, one way or another,
look on the side of the tire. for example. mine are 215x45x17
the 217 is the wideth
the 45 is the height
the 17 is the size (of rim).
look here:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=46
oops. i had it backwards
924-76
PostPosted: Sun Oct 17, 2010 8:38 pm    Post subject: Reply with quote
the 217 is the highth.
the 45 is the wideth
look here:
215 is the tire's section width
45 is the tire's section height, and also referred to as the tire's series, profile or aspect ratio.
1976 924 N/A ROW SOLD
1980 931S
1981 931 Part car RIP
emoore924
PostPosted: Mon Oct 18, 2010 2:17 am    Post subject: Reply with quote
Your best option: Tell him to put on the same size as you have now.
Just to clarify the numbering..., you'll see a set a 3 numbers on your sidewall, a two-digit number and a letter, and a bunch of other stuff.
The first set will be like you said xxx/yy/zz where xxx is essentially the width of the tire (section width), yy is the aspect ratio (the relationship between the sidewall height and the aformentioned width as a percent), and zz is the diameter of the wheel on which the tire can be mounted.
Sooooo, 225/50/15 means 225mm tread width, the sidewall is 50% of the width, or about 125mm, and it can be mounted on a 15 inch wheel. Don't ask me why they mixed metric and english..., I have no idea.
You might also see a "93W" or "89V" or something like that. That's the load and speed rating.
In reality, each tire varies a little from the numbering. Some 225s are wider than other 225s. Check the "specs" section at tire rack for details on a certain tire.
For ALL of this, go to http://www.tirerack.com
owenexile
PostPosted: Mon Oct 18, 2010 2:41 am    Post subject: Reply with quote
Ok thanks For all the help guys. Il let u know what my findings is tomorow
924 1982 N/A
PostPosted: Mon Oct 18, 2010 10:47 pm    Post subject: Reply with quote
+1
Also remember you can make it easier on yourself to convert to inches. Divide the section width by 25.4. You can multiply that number by the side wall percentage, double it and add the rim height to get total tire height in inches.
