MrElmwood Guest
Posted: Tue Jun 18, 2002 10:17 am Post subject: |
I need a head. There is one on ebay, part # 047 103 373. Mine is # 060 103 373. The former is off a '79 I believe. The latter I am not sure, maybe a '77. Fit, yes, no? Same except for valve size?
Stew in Winnipeg |
gohim Guest
Posted: Tue Jun 18, 2002 10:31 am Post subject: |
The part numbers cast onto the parts is not necessarily Porsche's Part Number that they stock the parts by.
Neither of the numbers that you posted are valid current, or old Porsche Part Numbers from what I can tell, so they must be casting numbers.
There are differences in the port size and shape, and the valve sizes. But any head from a 924 NA will bolt onto another 924 NA.
The earliest 924 cylinders seemed to develop the best power, and the latest heads probably cracked less often.
I have never owned a 924 with a smog pump, but the heads on the smog pump cars are probably different, and using one on a car that did not come with a smog pump would probably require some plugs.
If I had a 924 with small valves, I would definitely look into getting one with larger valves if I were replacing the head. If I were looking for a replacement head for my 81 (later 924), I would definitely look for an 80 or later head. |
JvGinPDX Guest
Posted: Tue Jun 18, 2002 11:36 am Post subject: |
| I have an early 77. When my head warped, I took it to an independant Porsche shop. I was told that the heads between the early 77 model and all of the later ones were not interchangable. He then hd the head baked and rebuilt, and cost me more money than I care to admit. My question is, was I lied to? Can any of the later heads work on an early 77 block? Has anyone acttually done this? |
friskynibbles Guest
Posted: Tue Jun 18, 2002 12:45 pm Post subject: |
i wonder if you could sue that bugger (if he lied to you)...
Richard Guest
Posted: Tue Jun 18, 2002 12:47 pm Post subject: |
| I just re-read an article by Jim Pasha in 1988 "Excellence" mag on 924 Engine hints and he specificaly states to use a later model head whenever doing performance work on a 1976-1977 1/2 924. He says use a 1980 1/2 or later head. It would seem, based on this info, that you were lied to. |
JvGinPDX Guest
Posted: Wed Jun 19, 2002 10:39 am Post subject: |
| Swell. I was 500 miles from home, in Sacramento. I could have come out of there with a more recent head with the larger valves. *&%#@!!!!! |
8trdrvr Guest
Posted: Wed Jun 19, 2002 10:49 am Post subject: |
the machine shop bill to rebuild my entire 1982 924 NA head was like 700 bucks. not even sure if it was done right yet.
heads
heads
heads...
will it ever stop?
larso Guest
Posted: Wed Jun 19, 2002 5:10 pm Post subject: |
| The pistons are different so wouldn't the head be different? some of them have ears for the valves, and some of them are cups, with no ears...Anyone know? Are the later pinstons the ones with ears, and the earlier ones cups? |
gohim Guest
Posted: Wed Jun 19, 2002 10:44 pm Post subject: |
All 924NA engine are 2.0L, and the combustion chamber is in the piston on all 924NA engines.
All the product 924 NA engines had pistons with the cup on the pistons. This was/is the combustion chamber.
The valve size varies over the years, but the stock NA engine is never "interference" type, so there is no reason that the cylinder head from one year will not fit on the block of another. |
coconutcowboy Guest
Posted: Thu Jun 20, 2002 12:05 am Post subject: |
For $700 you got ripped .
For a little over $900 you could have had your head rebuilt with big valves at eurorace. add another $300 - $350 for a new integral cam and ....
Sean Ross A@P
8trdrvr Guest
Posted: Thu Jun 20, 2002 1:14 am Post subject: |
thanks for the salt in the wound Coco i know i set myself up for it. whats even worse is the car dosnt even run. enough bi*ching by me, i'll post whenever it is i get this situation squared away and have my car back so i can work on it with you guys
