4 Lug caliper rebuild kit update
PostPosted: Mon May 31, 2010 8:24 am    Post subject: 4 Lug caliper rebuild kit update Reply with quote
Centric the makers added them to their main distributors website
http://store.zeckhausen.com/catalog/index.php?cPath=88_2958_2965_2959
after i emailed them to check fitment as opposed to 924 turbo/s seals
Have no idea if they fit but here are is the email from centric
143.33006 is the correct part number. Each kit repairs ONE (1) caliper.
These are in stock in our California warehouse. NO distributors stock these kits. Please order them via www.zeckhausen.com . Simply send an e-mail to Dave. He will take care of you and any other 924board members. Note that he does not list every part number on his site.
I guarantee that you will be very satisfied with his level of customer service and knowledge.
I cannot speak for www.car-stuff.com as I truly have no idea who they are. But they will likely take your order, try to order it from a Centric distributor as they cannot buy from us, then work out shipping to you. All of this may not be visible, but it is generally not the way you want to buy product.
and then from the Zechausen president guy
You can find the brake parts you need for your 1979 Porsche 924 here:
If you plan to replace the caliper pressure seals, and not just the dust boots, I suggest using caliper assembly lube rather than brake fluid. It's slipperier than brake fluid and will make it easier to insert your pistons, with less chance of tearing or twisting the pressure seals. You can find it here, in case you can't source any locally: http://store.zeckhausen.com/catalog/product_info.php?products_id=2967. This should not be used on the dust boots, as they are installed dry.
If you have any other questions, feel free to call or email.
Sincerely,
David Zeckhausen
President, Zeckhausen Racing
(800)222-8893 x1
www.zeckhausen.com
1979 NA
my Porsches Arse!!!
KDJones2000
PostPosted: Tue Sep 14, 2010 8:33 am    Post subject: Reply with quote
Thanks for this info! I would have never found a source for these things without this forum
Cheers, Keith
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
